New node material system
jagger
Hi! I have a doubt, in the new Luxology video showing the new nodal system, the shader is using some specific channels that are not available in the octane render. The speaker is using some kind of reflection channel to put green in the wet part of the object (see the vid!).. so could octane use this channel?
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
This channel is be available to plugins. However, I'm not sure what you would do with it in the Modo plugin.
Return to “Foundry Modo”
