Hi there,
I have a simple scene setup and trying to do a multipass render of about 90 frames. I am using mixed materials. I've tried rendering to picture viewer a few times and it only renders the first frame fully and then on the remaining frames ONLY the multipass frames are rendered and not the main beauty pass. Can anyone provide any insight into this problem?
Nick Bauer
MultiPass Render Issue
is it for standalone?
so you're lucky that's seen here. I hope that you are using version 1.52.1 or 1.01?Bowser16NB wrote:No within C4D plugin
can you give me more info?
- Lobster_Johnson
Same issue here. I am trying to render EXRs with object buffers and a depth pass. One frame works great, but all subsequent frames are rendering depth into the RGB channels. Removing the depth from multi-pass fixes the issue.
Can you guys check on what would be causing this? We need our depth passes.
Ian
Ian
ahh, i see. My bad. I'll post a fix version.
But try with kernel overwrite on render settings until fixed
EDIT:
could you try this for multipass rendering?
http://render.otoy.com/customerdownload ... -test1.zip
EDIT:
- JessicaVines
Mac compatible?
Thanks for the fast action.
