Vs modo render
jagger
Hi, I would like to know what are the advantages and disadvantages of octane vs modo engine.
I suppose that octane is faster and modos engine is better integrated.
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
Talleman
Modo is Biased, Octane is unbiased...
Unbiased does not necessarily mean faster.
Modo's engine is more integrated, and supports more features. It is also faster in a lot of ways.
Octane is fast (for some things) and physically accurate. Brute force. Easy to set up the render.
Thomas Alleman
3D Generalist
Those who get wisdom do themselves a favor, and those who love learning will succeed.
jagger
What are the things that cannot be done in octane in comparision to modo?
(I mean octane 2.0)
Battery555
Just to add one point. Image Realism is what I care and Octane got it there!
The plugin supports the majority of Modo features. The limitations are covered at http://render.otoy.com/manuals/Modo/?page_id=185 - although Render Curves is included in Octane 2. Rendering Proxies is being pushed into the longer-term, since it is going to be quite complex to implement. Support for Modo procedural textures will be started soon, and will be ongoing - but realistically, only a sub-set of Modo procudurals will be able be converted to Octane node equivalents.
cuffi
Talleman wrote:Modo is Biased, Octane is unbiased...
I thought the same way until I listened to the Modcast(http://community.thefoundry.co.uk/modca ... spx?id=267)with Allen Hastings. Modo in fact is being able to render biased and unbiased. There is an unbiased render attribute in the channel list of the render item...Unbiased by the way doesn't mean physically correct necessarily...
EDIT:
You have to set the preview renderer to "Full Resolution" and the Quality to "Extended Refinement" passes in the Options of the preview window for a unbiased rendering in the preview. Along with the statements of Allen Hastings regarding to physically correct rendering (no clamping, low specularity etc.) in the Modcast, we should be able to render in MODO unbiased and physically correct. Referring to Wikipedia "Pathtracing" means Monte Carlo Algorithm wich we still have in MODO (when IC is switched off) and we can Mix IC and MC now in MODO 801. This should give us faster and cleaner images with less flickering in animations. I have to test this shiny new world... :)
Win 7 Ultimate 64 Bit | GTX780 Ti | GTX 560 TI | Driver Version 337.88 | Intel Core i7 3930K 6x 3,2 GHz | 32 GB RAM
Web: http://www.mentalarts.com
Talleman
EDIT:
When you switch the Modo renderer over to unbiased, you loose the speed advantage that Modo has. The biased nature of Modo makes for faster renders at the expense of accuracy.
In a straight Brute force contest between Octane and Modo, Octane should win (dependant on gpu).
Thomas Alleman
3D Generalist
jagger
Ok, I´ll change the question. Why should I choose Modos renderer over Octane?
riggles
rushes wrote:Ok, I´ll change the question. Why should I choose Modos renderer over Octane?
MODOs renderer still has some advantages over Octane. For one, it's completely integrated, so all MODO features are supported. Particles, variation textures, texture offsets, procedurals, gradients, cell shaders, and many more things all work, but not in Octane. There are dedicated fur and skin shaders as well. And until Octane 2.0 and 2.x features are released, even things like displacement, render passes, and object motion blur can only be had with MODOs renderer. MODOs preview render also offers features that Octane doesn't, such as the ability to preview specific outputs (AOVs).
Then there are other rendering scenarios where MODO might be better. I've found that product shots can render cleaner and faster using MODO irradiance caching than Octane's brute force unbiased method.
So, whether Octane or MODO is better really depends on what kind of renders to need to produce and what features you need to produce them.
riggles
MODOs renderer still has some advantages over Octane. For one, it's completely integrated, so all MODO features are supported. Particles, variation textures, texture offsets, procedurals, gradients, cell shaders, render booleans, proxies, and many more things all work, but not in Octane. There are dedicated fur and skin shaders as well. And until Octane 2.0 and 2.x features are released, even things like displacement, render passes, and object motion blur can only be had with MODOs renderer. MODOs preview render also offers features that Octane doesn't, such as the ability to preview specific outputs (AOVs).
Return to “Foundry Modo”
