multiple GPU's motherboard suggestion
pavel
I am planning to buy 2 gtx 780 6gb that have to be released in a few days and with my current gtx 780 3gb i will need another motherboard to fit all 3 and the future GPU's that i will buy. Can someone please suggest me a good socket 1150 motherboard which fits multiple GPU's (at least 4) please? Is there any motherboard or solution to install more than 4 GPU's?
Thank you
i7 4770k, GTX780, 16gb ddr
slepy8
yes
ASROCK H81 pro BTC.
I'm building the machine now on this motherboard.
Target is 6 GPU's
schodt
Slepy8 - Isn't it going to take forever to load textures on that mobo when it only has PCIe 2.0 x1 speed?
Workstation: Watercooled 4x GTX 780, 1500W Corsair AX1500i PSU, 4930K, 32 GB RAM, SSD and Cinema4D.
Render slave: 4X GTX 780 Asus Strix 6GB, 1200W Corsair AX1200i PSU
slepy8
I made tests and had no problems at all.
However remember when you get 16X slots motherboard and connect more GPUs than one they become X8 and smallers.
Today I'm connecting everything together - waiting for an acustic foam to come. Tomorrow I'll show some results of how it works and how it looks.
schodt
Sounds great - would love to see some pictures of how your setup will look like! Good luck :)
glimpse
slepy8 wrote: Today I'm connecting everything together - waiting for an acustic foam to come. Tomorrow I'll show some results of how it works and how it looks.
cool - looking' forward for Your insights =) that might be a nice slave
(though personally I don't know if I would build main rig with multiple x1)
pavel wrote: Is there any motherboard or solution to install more than 4 GPU's?
Yes there're are server grade backplanes with multiple 8x & 20 slot spacing like BPG8032.
However with the socket You've mentioned You're stuck in ATX, EATX layouts that have 8 slot spacing that in theory could house four dual slot cards (unless using ribbon cables =) but even this is possible with just a few higher end mobs that have PLX chips in order to provide more lanes =)
Alternatively =) if You very crazy, You can buy a board with let's say seven x8 slots, hard-mod Titans/780 to single slot water-cooled cards (cutting out some conections & changing brackets, adding water blocks) & then house them all side by side - insane density in a regular ATX case with some space for rads - think of 7 Titans =)
slepy8
@Tom - what's the problem with multiple X1 slots?
riggles
glimpse wrote:However with the socket You've mentioned You're stuck in ATX, EATX layouts that have 8 slot spacing that in theory could house four dual slot cards (unless using ribbon cables =) but even this is possible with just a few higher end mobs that have PLX chips in order to provide more lanes =)
Does the PLX chip actually add more PCIe lanes? Or does it just off-load managing the existing traffic to a dedicated chip? I never fully understood.
voon
They're switches ... the PCI lanes are limited by what the CPU can handle. The PLXes switch between one card and another, but that happens actually pretty fast. Ideally, you should spread the cards in a way, that they won't hog the same PLX if you are not using all slots.
slepy8
The Rig I was talkng about recently.
http://render.otoy.com/forum/viewtopic.php?f=40&t=39500
peace!
