Glossy -> Diffuse Nodes
3dxcentric
Hey all,
Long time reader, first time poster. I apologize if I'm asking a question that's clearly documented, but I haven't had much luck finding an answer. Is there a way to change "all" of the nodes for a particular element to 'diffuse' with a single click, rather than having to go line-by-line? Or a setting to make all imports from Poser default to diffuse rather than glossy, as they are now?
Thanks!
Hi. Poser does not allow the selection of multiple figure/props or materials, so multiple selection of figures/props and materials is not currently supported in the plugin - so no, you cannot select 5 materials and change them all to diffuse. However if you turn off all the specular in the Poser material (by setting the specular to black/0), the re-converting all the materials for the figure/prop or scene will result in all the materials being diffuse rather than glossy (since they have no specular in the Poser Material). If you want to change the specular on a lot of Poser materials, you can use one of the material room plugins which allow editing of multiple materials at once.
Hope that answers your question.
3dxcentric
It does indeed. Thanks sir.
Return to “Poser”
