Several problem with iMac
Kotoboy
The product is amazing but I have some problems with the Poser plugin, and I don't know if is caused by my iMac or if is something I'm missing with the configuration. Several times the vieport, it alert me: "low video card memory”.
Or if I try to export the same scene in OCS, to render directly in Octane, several times it crash (this it happens when I change output resolution), or stop rendering (when I change the kernel).
The problem it happens with simple (V4 + Hair + Dress + Shoes + Plane) or complex scenes.
One last thing: when I open Poser (after restarting the system) the program tell me: "ERROR: [Errno 2] No such file or directory....", but if I restart Poser the alert it doesn't show anymore.
Than you
K.
i5 CPU - 750 2.67 GHz
RAM: 8 Gb
Windows 7 (64 bit)
Graphic card: NVIDIA GeForce GTX 760
Octane 2.0 DazStudio + Standalone 2.0 + Daz Studio 4.7
Octane 1.5 Poser + Standalone 2.0 + Poser Pro 2012
Hi
I suspect a lot of your issues may be due to having limited VRAM (graphic card RAM) - as indicated by the "low video card memory” alert. 1GB is a very small VRAM amount to work with. Poser needs VRAM to display the preview, and your Octane scene will also be used it - so you are potentially running out.
To minimise VRAM use by Poser, under Render->Render Settings->Preview, try SreeD, or if using OpenGL set the Preview Resolution to the minimum. You can also use the Compress Texture Maps script to minimise the size of the textures that lo into VRAM.
Are you able to post the octaneplugin.log pls? To find this, see the TEST or RELEASE thread in this forum.
Kotoboy
Thank you!!!!
DEBUG:root:Python Version : 2.7
DEBUG:root:Platform : darwin
DEBUG:root:OS Architecture : 64bit
DEBUG:root:Poser Version : 9.0
DEBUG:root:Poser App Version : 9.0.3 .23027
DEBUG:root:Plugin Version : 1.50.0.22
DEBUG:root:OctanePlugin.py = /Applications/Poser Pro 2012/Runtime/Python/addons/OctaneRender for Poser/OctaneWrapper.pyc
DEBUG:root:OctaneDefaults.py = /Applications/Poser Pro 2012/Runtime/Python/addons/OctaneRender for Poser/OctaneDefaults.pyc
DEBUG:root:Loading Octane library /Applications/Poser Pro 2012/Runtime/Python/addons/OctaneRender for Poser/OSX/libPoserOctaneOSX.dylib
DEBUG:root:Paths
DEBUG:root:/Applications/Poser Pro 2012/Runtime/Python/addons/OctaneRender for Poser/OSX
DEBUG:root:/Applications/Poser Pro 2012/Runtime/Python/poserScripts
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Resources/site-packages/wx-2.9.1-osx_cocoa
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Resources/site-packages/numarray
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Resources/site-packages/Numeric
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python27.zip
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload
DEBUG:root:/Applications/Poser Pro 2012/Poser Pro 2012.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
DEBUG:root:/Library/Python/2.7/site-packages
DEBUG:root:/Applications/Poser Pro 2012/Runtime/Python/PoserScripts
DEBUG:root:octane.dat: date/time = Tue Mar 25 02:25:44 2014, filesize = 10816021
DEBUG:root:Current Directory = /Applications/Poser Pro 2012/Runtime/Python/addons/OctaneRender for Poser/OSX
DEBUG:root:Octane library loaded
DEBUG:root:addon:__init__
DEBUG:root:addon:load
DEBUG:root:init:sceneCreated
DEBUG:root:init:objectsAdded
DEBUG:root:addon:render
DEBUG:root:Opening username from /Users/kotoboy/Library/Preferences/Poser Pro/9/access.orp
DEBUG:root:Calling Start
DEBUG:root:PoserOctaneAuthenticate returned True
DEBUG:root:Light 4 set as Sunlight
DEBUG:root:Octane License is activated
DEBUG:root:No scene root node set to clear
DEBUG:root:No rendertarget set to clear
DEBUG:root:Creating default rendertarget
DEBUG:root:Environment Texturemap = /Users/Shared/Poser Pro 2012 Content/Runtime/Textures/LightProbes/OfficeFoyerBG_512.jpg
DEBUG:root:init:objectsRenamed
DEBUG:root:Ignoring rename of non figure/prop figure Light 4 to Daylight
DEBUG:root:Converting material 1_EyeSocket from Poser Material
DEBUG:root:setting 1_EyeSocket to glossy
DEBUG:root:Converting material 1_Eyebrow from Poser Material
DEBUG:root:setting 1_Eyebrow to glossy
DEBUG:root:Converting material 1_Lip from Poser Material
DEBUG:root:setting 1_Lip to glossy skin
DEBUG:root:Converting material 1_Nostril from Poser Material
DEBUG:root:setting 1_Nostril to glossy skin
DEBUG:root:Converting material 1_SkinFace from Poser Material
DEBUG:root:setting 1_SkinFace to glossy skin
DEBUG:root:Converting material 2_Nipple from Poser Material
DEBUG:root:setting 2_Nipple to glossy skin
DEBUG:root:Converting material 2_SkinHead from Poser Material
DEBUG:root:setting 2_SkinHead to glossy skin
DEBUG:root:Converting material 2_SkinHip from Poser Material
DEBUG:root:setting 2_SkinHip to glossy skin
DEBUG:root:Converting material 2_SkinNeck from Poser Material
DEBUG:root:setting 2_SkinNeck to glossy skin
DEBUG:root:Converting material 2_SkinTorso from Poser Material
DEBUG:root:setting 2_SkinTorso to glossy skin
DEBUG:root:Converting material 3_Fingernail from Poser Material
DEBUG:root:setting 3_Fingernail to glossy
DEBUG:root:Converting material 3_SkinArm from Poser Material
DEBUG:root:setting 3_SkinArm to glossy skin
DEBUG:root:Converting material 3_SkinFoot from Poser Material
DEBUG:root:setting 3_SkinFoot to glossy skin
DEBUG:root:Converting material 3_SkinForearm from Poser Material
DEBUG:root:setting 3_SkinForearm to glossy skin
DEBUG:root:Converting material 3_SkinHand from Poser Material
DEBUG:root:setting 3_SkinHand to glossy skin
DEBUG:root:Converting material 3_SkinLeg from Poser Material
DEBUG:root:setting 3_SkinLeg to glossy skin
DEBUG:root:Converting material 3_Toenail from Poser Material
DEBUG:root:setting 3_Toenail to glossy
DEBUG:root:Converting material 4_Gums from Poser Material
DEBUG:root:setting 4_Gums to glossy
DEBUG:root:Converting material 4_InnerMouth from Poser Material
DEBUG:root:setting 4_InnerMouth to glossy
DEBUG:root:Converting material 4_Teeth from Poser Material
DEBUG:root:setting 4_Teeth to glossy
DEBUG:root:Converting material 4_Tongue from Poser Material
DEBUG:root:setting 4_Tongue to glossy
DEBUG:root:Converting material 5_Cornea from Poser Material
DEBUG:root:setting 5_Cornea to glossy
DEBUG:root:Converting material 5_Iris from Poser Material
DEBUG:root:setting 5_Iris to glossy
DEBUG:root:Converting material 5_Lacrimal from Poser Material
DEBUG:root:setting 5_Lacrimal to glossy
DEBUG:root:Converting material 5_Pupil from Poser Material
DEBUG:root:setting 5_Pupil to glossy
DEBUG:root:Converting material 5_Sclera from Poser Material
DEBUG:root:setting 5_Sclera to glossy
DEBUG:root:Converting material 6_Eyelash from Poser Material
DEBUG:root:setting 6_Eyelash to glossy
DEBUG:root:Converting material 7_EyeSurface from Poser Material
DEBUG:root:setting 7_EyeSurface to glossy
DEBUG:root:Converting material 7_Tear from Poser Material
DEBUG:root:setting 7_Tear to invisible diffuse
DEBUG:root:Converting material Preview from Poser Material
DEBUG:root:setting Preview to glossy
DEBUG:root:EventTreeSelection : node = texture
DEBUG:root:Node.RestoreTreePosition setting first visible node to : rendertarget
DEBUG:root:Node.RestoreTreeState found selected item texture
DEBUG:root:Node.SelectTreeItem for texture
DEBUG:root:Clearing scene root node
DEBUG:root:Clearing rendertarget node
DEBUG:root:Found material 1_EyeSocket for Victoria4 in saveTreeInfo
DEBUG:root:Found material 1_Eyebrow for Victoria4 in saveTreeInfo
DEBUG:root:Found material 1_Lip for Victoria4 in saveTreeInfo
DEBUG:root:Found material 1_Nostril for Victoria4 in saveTreeInfo
DEBUG:root:Found material 1_SkinFace for Victoria4 in saveTreeInfo
DEBUG:root:Found material 2_Nipple for Victoria4 in saveTreeInfo
DEBUG:root:Found material 2_SkinHead for Victoria4 in saveTreeInfo
DEBUG:root:Found material 2_SkinHip for Victoria4 in saveTreeInfo
DEBUG:root:Found material 2_SkinNeck for Victoria4 in saveTreeInfo
DEBUG:root:Found material 2_SkinTorso for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_Fingernail for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_SkinArm for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_SkinFoot for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_SkinForearm for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_SkinHand for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_SkinLeg for Victoria4 in saveTreeInfo
DEBUG:root:Found material 3_Toenail for Victoria4 in saveTreeInfo
DEBUG:root:Found material 4_Gums for Victoria4 in saveTreeInfo
DEBUG:root:Found material 4_InnerMouth for Victoria4 in saveTreeInfo
DEBUG:root:Found material 4_Teeth for Victoria4 in saveTreeInfo
DEBUG:root:Found material 4_Tongue for Victoria4 in saveTreeInfo
DEBUG:root:Found material 5_Cornea for Victoria4 in saveTreeInfo
DEBUG:root:Found material 5_Iris for Victoria4 in saveTreeInfo
DEBUG:root:Found material 5_Lacrimal for Victoria4 in saveTreeInfo
DEBUG:root:Found material 5_Pupil for Victoria4 in saveTreeInfo
DEBUG:root:Found material 5_Sclera for Victoria4 in saveTreeInfo
DEBUG:root:Found material 6_Eyelash for Victoria4 in saveTreeInfo
DEBUG:root:Found material 7_EyeSurface for Victoria4 in saveTreeInfo
DEBUG:root:Found material 7_Tear for Victoria4 in saveTreeInfo
DEBUG:root:Found material Preview for Victoria4 in saveTreeInfo
DEBUG:root:Opening Viewport - registering log callback
DEBUG:root:Opening Viewport - reseting Octane project
DEBUG:root:Opening Viewport - clearing node references
DEBUG:root:Opening Viewport - reseting progressive save
DEBUG:root:Opening Viewport - creating Octane rendertarget nodes
DEBUG:root:Opening Viewport - loading geometry
DEBUG:root:geometrygroup node created with 1 pins
DEBUG:root:total number of vertices = 69759, vertex indices = 264096, normals = 69759, uvs = 72605, uv indices = 264096, polygons = 66024
DEBUG:root:transferring actor Victoria4 : Hip geometry to octane
DEBUG:root: number of vertices = 1279, normals = 1279, uvs = 1313, polygons = 1152, sets = 4608, texture sets = 4608
DEBUG:root:transferring actor Victoria4 : Abdomen geometry to octane
DEBUG:root: number of vertices = 2362, normals = 2362, uvs = 2381, polygons = 2270, sets = 9080, texture sets = 9080
DEBUG:root:transferring actor Victoria4 : Chest geometry to octane
DEBUG:root: number of vertices = 3914, normals = 3914, uvs = 3967, polygons = 3732, sets = 14928, texture sets = 14928
DEBUG:root:transferring actor Victoria4 : Neck geometry to octane
DEBUG:root: number of vertices = 754, normals = 754, uvs = 795, polygons = 676, sets = 2704, texture sets = 2704
DEBUG:root:transferring actor Victoria4 : Head geometry to octane
DEBUG:root: number of vertices = 15078, normals = 15078, uvs = 15393, polygons = 14022, sets = 56088, texture sets = 56088
DEBUG:root:transferring actor Victoria4 : rEye geometry to octane
DEBUG:root: number of vertices = 2099, normals = 2099, uvs = 2115, polygons = 2048, sets = 8192, texture sets = 8192
DEBUG:root:transferring actor Victoria4 : lEye geometry to octane
DEBUG:root:transferring actor Victoria4 : upperJaw geometry to octane
DEBUG:root: number of vertices = 4869, normals = 4869, uvs = 5085, polygons = 4662, sets = 18648, texture sets = 18648
DEBUG:root:transferring actor Victoria4 : lowerJaw geometry to octane
DEBUG:root: number of vertices = 5478, normals = 5478, uvs = 5742, polygons = 5230, sets = 20920, texture sets = 20920
DEBUG:root:transferring actor Victoria4 : tongueBase geometry to octane
DEBUG:root: number of vertices = 132, normals = 132, uvs = 135, polygons = 88, sets = 352, texture sets = 352
DEBUG:root:transferring actor Victoria4 : tongue01 geometry to octane
DEBUG:root: number of vertices = 220, normals = 220, uvs = 225, polygons = 176, sets = 704, texture sets = 704
DEBUG:root:transferring actor Victoria4 : tongue02 geometry to octane
DEBUG:root:transferring actor Victoria4 : tongue03 geometry to octane
DEBUG:root: number of vertices = 208, normals = 208, uvs = 213, polygons = 166, sets = 664, texture sets = 664
DEBUG:root:transferring actor Victoria4 : tongue04 geometry to octane
DEBUG:root: number of vertices = 172, normals = 172, uvs = 177, polygons = 136, sets = 544, texture sets = 544
DEBUG:root:transferring actor Victoria4 : tongue05 geometry to octane
DEBUG:root: number of vertices = 176, normals = 176, uvs = 178, polygons = 140, sets = 560, texture sets = 560
DEBUG:root:transferring actor Victoria4 : tongueTip geometry to octane
DEBUG:root: number of vertices = 149, normals = 149, uvs = 149, polygons = 128, sets = 512, texture sets = 512
DEBUG:root:transferring actor Victoria4 : Right Collar geometry to octane
DEBUG:root: number of vertices = 1260, normals = 1260, uvs = 1322, polygons = 1192, sets = 4768, texture sets = 4768
DEBUG:root:transferring actor Victoria4 : Right Shoulder geometry to octane
DEBUG:root: number of vertices = 1218, normals = 1218, uvs = 1245, polygons = 1176, sets = 4704, texture sets = 4704
DEBUG:root:transferring actor Victoria4 : Right Forearm geometry to octane
DEBUG:root: number of vertices = 580, normals = 580, uvs = 595, polygons = 541, sets = 2164, texture sets = 2164
DEBUG:root:transferring actor Victoria4 : Right Hand geometry to octane
DEBUG:root: number of vertices = 1504, normals = 1504, uvs = 1555, polygons = 1436, sets = 5744, texture sets = 5744
DEBUG:root:transferring actor Victoria4 : rThumb1 geometry to octane
DEBUG:root: number of vertices = 342, normals = 342, uvs = 353, polygons = 310, sets = 1240, texture sets = 1240
DEBUG:root:transferring actor Victoria4 : rThumb2 geometry to octane
DEBUG:root: number of vertices = 290, normals = 290, uvs = 305, polygons = 268, sets = 1072, texture sets = 1072
DEBUG:root:transferring actor Victoria4 : rThumb3 geometry to octane
DEBUG:root: number of vertices = 407, normals = 407, uvs = 446, polygons = 394, sets = 1576, texture sets = 1576
DEBUG:root:transferring actor Victoria4 : rIndex1 geometry to octane
DEBUG:root: number of vertices = 144, normals = 144, uvs = 162, polygons = 128, sets = 512, texture sets = 512
DEBUG:root:transferring actor Victoria4 : rIndex2 geometry to octane
DEBUG:root:transferring actor Victoria4 : rIndex3 geometry to octane
DEBUG:root: number of vertices = 371, normals = 371, uvs = 411, polygons = 360, sets = 1440, texture sets = 1440
DEBUG:root:transferring actor Victoria4 : rMid1 geometry to octane
DEBUG:root: number of vertices = 150, normals = 150, uvs = 164, polygons = 132, sets = 528, texture sets = 528
DEBUG:root:transferring actor Victoria4 : rMid2 geometry to octane
DEBUG:root: number of vertices = 150, normals = 150, uvs = 168, polygons = 132, sets = 528, texture sets = 528
DEBUG:root:transferring actor Victoria4 : rMid3 geometry to octane
DEBUG:root:transferring actor Victoria4 : rRing1 geometry to octane
DEBUG:root:transferring actor Victoria4 : rRing2 geometry to octane
DEBUG:root:transferring actor Victoria4 : rRing3 geometry to octane
DEBUG:root:transferring actor Victoria4 : rPinky1 geometry to octane
DEBUG:root: number of vertices = 120, normals = 120, uvs = 134, polygons = 104, sets = 416, texture sets = 416
DEBUG:root:transferring actor Victoria4 : rPinky2 geometry to octane
DEBUG:root:transferring actor Victoria4 : rPinky3 geometry to octane
DEBUG:root: number of vertices = 403, normals = 403, uvs = 447, polygons = 392, sets = 1568, texture sets = 1568
DEBUG:root:transferring actor Victoria4 : Left Collar geometry to octane
DEBUG:root:transferring actor Victoria4 : Left Shoulder geometry to octane
DEBUG:root:transferring actor Victoria4 : Left Forearm geometry to octane
DEBUG:root:transferring actor Victoria4 : Left Hand geometry to octane
DEBUG:root:transferring actor Victoria4 : lThumb1 geometry to octane
DEBUG:root:transferring actor Victoria4 : lThumb2 geometry to octane
DEBUG:root:transferring actor Victoria4 : lThumb3 geometry to octane
DEBUG:root:transferring actor Victoria4 : lIndex1 geometry to octane
DEBUG:root:transferring actor Victoria4 : lIndex2 geometry to octane
DEBUG:root:transferring actor Victoria4 : lIndex3 geometry to octane
DEBUG:root:transferring actor Victoria4 : lMid1 geometry to octane
DEBUG:root:transferring actor Victoria4 : lMid2 geometry to octane
DEBUG:root:transferring actor Victoria4 : lMid3 geometry to octane
DEBUG:root:transferring actor Victoria4 : lRing1 geometry to octane
DEBUG:root:transferring actor Victoria4 : lRing2 geometry to octane
DEBUG:root:transferring actor Victoria4 : lRing3 geometry to octane
DEBUG:root:transferring actor Victoria4 : lPinky1 geometry to octane
DEBUG:root:transferring actor Victoria4 : lPinky2 geometry to octane
DEBUG:root:transferring actor Victoria4 : lPinky3 geometry to octane
DEBUG:root:transferring actor Victoria4 : Right Thigh geometry to octane
DEBUG:root: number of vertices = 1701, normals = 1701, uvs = 1793, polygons = 1631, sets = 6524, texture sets = 6524
DEBUG:root:transferring actor Victoria4 : Right Shin geometry to octane
DEBUG:root: number of vertices = 1778, normals = 1778, uvs = 1821, polygons = 1733, sets = 6932, texture sets = 6932
DEBUG:root:transferring actor Victoria4 : Right Foot geometry to octane
DEBUG:root: number of vertices = 1044, normals = 1044, uvs = 1075, polygons = 985, sets = 3940, texture sets = 3940
DEBUG:root:transferring actor Victoria4 : rToe geometry to octane
DEBUG:root: number of vertices = 2483, normals = 2483, uvs = 2724, polygons = 2433, sets = 9732, texture sets = 9732
DEBUG:root:transferring actor Victoria4 : Left Thigh geometry to octane
DEBUG:root:transferring actor Victoria4 : Left Shin geometry to octane
DEBUG:root:transferring actor Victoria4 : Left Foot geometry to octane
DEBUG:root:transferring actor Victoria4 : lToe geometry to octane
DEBUG:root: Mesh node for Victoria4 created
DEBUG:root:creating new objectlayermap node
DEBUG:root:Opening Viewport - setting rendertarget
DEBUG:root:EventTreeSelection : node = postproc
DEBUG:root:EventTreeSelection : node = environment
DEBUG:root:Node.RestoreTreeState found selected item environment
DEBUG:root:Node.SelectTreeItem for environment
DEBUG:root:init:sceneDeleted
DEBUG:root:Closing settings window - clearing callback
DEBUG:root:Closing settings window - saving window locations
DEBUG:root:Closing settings window - reseting project
DEBUG:root:Closing settings window - destroying window
DEBUG:root:ignoring init:objectsDeleted
DEBUG:root:Light 1 set as Sunlight
DEBUG:root:Ignoring rename of non figure/prop figure Light 1 to Daylight
DEBUG:root:setting 1_Eyebrow to invisible diffuse
DEBUG:root:setting 7_EyeSurface to invisible diffuse
DEBUG:root:Converting material Default from Poser Material
DEBUG:root:setting Default to glossy
DEBUG:root:Converting material Bikini2_Pan from Poser Material
DEBUG:root:setting Bikini2_Pan to glossy
DEBUG:root:Converting material Bikini2_pStrap from Poser Material
DEBUG:root:setting Bikini2_pStrap to glossy
DEBUG:root:Converting material 096 from Poser Material
DEBUG:root:setting 096 to glossy
DEBUG:root:Converting material Buckle from Poser Material
DEBUG:root:setting Buckle to glossy
DEBUG:root:Converting material Heel from Poser Material
DEBUG:root:setting Heel to glossy
DEBUG:root:Converting material HeelFront from Poser Material
DEBUG:root:setting HeelFront to glossy
DEBUG:root:Converting material HeelTop from Poser Material
DEBUG:root:setting HeelTop to glossy
DEBUG:root:Converting material InsoleBottom from Poser Material
DEBUG:root:setting InsoleBottom to glossy
DEBUG:root:Converting material Insoles from Poser Material
DEBUG:root:setting Insoles to glossy
DEBUG:root:Converting material Mesh from Poser Material
DEBUG:root:setting Mesh to glossy
DEBUG:root:Converting material Outsole from Poser Material
DEBUG:root:setting Outsole to glossy
DEBUG:root:Converting material Sole from Poser Material
DEBUG:root:setting Sole to glossy
DEBUG:root:Converting material Straps from Poser Material
DEBUG:root:setting Straps to glossy
DEBUG:root:Converting material StrapsInner from Poser Material
DEBUG:root:setting StrapsInner to glossy
DEBUG:root:Converting material SB_Belt from Poser Material
DEBUG:root:setting SB_Belt to glossy
DEBUG:root:Converting material SB_Hat from Poser Material
DEBUG:root:setting SB_Hat to glossy
DEBUG:root:Converting material SB_Jacket from Poser Material
DEBUG:root:setting SB_Jacket to glossy
DEBUG:root:Converting material SB_PoBelt from Poser Material
DEBUG:root:setting SB_PoBelt to glossy
DEBUG:root:Converting material SB_Pocket from Poser Material
DEBUG:root:setting SB_Pocket to glossy
DEBUG:root:Converting material SB_ZipCloth from Poser Material
DEBUG:root:setting SB_ZipCloth to glossy
DEBUG:root:Converting material SB_Zipper from Poser Material
DEBUG:root:setting SB_Zipper to glossy
DEBUG:root:Converting material mb_ClothBottom from Poser Material
DEBUG:root:setting mb_ClothBottom to glossy
DEBUG:root:Converting material mb_ClothTop from Poser Material
DEBUG:root:setting mb_ClothTop to glossy
DEBUG:root:Converting material mb_Metal from Poser Material
DEBUG:root:setting mb_Metal to glossy
DEBUG:root:Converting material mb_Straps from Poser Material
DEBUG:root:setting mb_Straps to glossy
DEBUG:root:Converting material col1 from Poser Material
DEBUG:root:setting col1 to glossy
DEBUG:root:Converting material col2 from Poser Material
DEBUG:root:setting col2 to glossy
DEBUG:root:Converting material Mbox01 from Poser Material
DEBUG:root:setting Mbox01 to glossy
DEBUG:root:Converting material Mbox02 from Poser Material
DEBUG:root:setting Mbox02 to glossy
DEBUG:root:Converting material Mfascia01 from Poser Material
DEBUG:root:setting Mfascia01 to glossy
DEBUG:root:Converting material Mfascia02 from Poser Material
DEBUG:root:setting Mfascia02 to glossy
DEBUG:root:Converting material Mmuro from Poser Material
DEBUG:root:setting Mmuro to glossy
DEBUG:root:Converting material Mquadra01 from Poser Material
DEBUG:root:setting Mquadra01 to glossy
DEBUG:root:Converting material Mquadra02 from Poser Material
DEBUG:root:setting Mquadra02 to glossy
DEBUG:root:EventTreeSelection : node = resolution
DEBUG:root:Found material Default for Victoria4 in saveTreeInfo
DEBUG:root:Found material Bikini2_Pan for Pantie in saveTreeInfo
DEBUG:root:Found material Bikini2_pStrap for Pantie in saveTreeInfo
DEBUG:root:Found material Preview for Pantie in saveTreeInfo
DEBUG:root:Found material 096 for Hr-096 in saveTreeInfo
DEBUG:root:Found material Preview for Hr-096 in saveTreeInfo
DEBUG:root:Found material Buckle for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Heel for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material HeelFront for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material HeelTop for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material InsoleBottom for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Insoles for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Mesh for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Outsole for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Preview for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Sole for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Straps for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material StrapsInner for V4EleganceSandals in saveTreeInfo
DEBUG:root:Found material Preview for Jacket in saveTreeInfo
DEBUG:root:Found material SB_Belt for Jacket in saveTreeInfo
DEBUG:root:Found material SB_Hat for Jacket in saveTreeInfo
DEBUG:root:Found material SB_Jacket for Jacket in saveTreeInfo
DEBUG:root:Found material SB_PoBelt for Jacket in saveTreeInfo
DEBUG:root:Found material SB_Pocket for Jacket in saveTreeInfo
DEBUG:root:Found material SB_ZipCloth for Jacket in saveTreeInfo
DEBUG:root:Found material SB_Zipper for Jacket in saveTreeInfo
DEBUG:root:Found material Preview for V4MiniBikiniTop in saveTreeInfo
DEBUG:root:Found material mb_ClothBottom for V4MiniBikiniTop in saveTreeInfo
DEBUG:root:Found material mb_ClothTop for V4MiniBikiniTop in saveTreeInfo
DEBUG:root:Found material mb_Metal for V4MiniBikiniTop in saveTreeInfo
DEBUG:root:Found material mb_Straps for V4MiniBikiniTop in saveTreeInfo
DEBUG:root:Found material Preview for V4-AO6_Bracelet in saveTreeInfo
DEBUG:root:Found material col1 for V4-AO6_Bracelet in saveTreeInfo
DEBUG:root:Found material col2 for V4-AO6_Bracelet in saveTreeInfo
DEBUG:root:Found material Preview for GROUND in saveTreeInfo
DEBUG:root:Found material Mbox01 for muro in saveTreeInfo
DEBUG:root:Found material Mbox02 for muro in saveTreeInfo
DEBUG:root:Found material Mfascia01 for muro in saveTreeInfo
DEBUG:root:Found material Mfascia02 for muro in saveTreeInfo
DEBUG:root:Found material Mmuro for muro in saveTreeInfo
DEBUG:root:Found material Mquadra01 for muro in saveTreeInfo
DEBUG:root:Found material Mquadra02 for muro in saveTreeInfo
DEBUG:root:Found material Preview for muro in saveTreeInfo
DEBUG:root:Found material Mbox01 for muro 1 in saveTreeInfo
DEBUG:root:Found material Mbox02 for muro 1 in saveTreeInfo
DEBUG:root:Found material Mfascia01 for muro 1 in saveTreeInfo
DEBUG:root:Found material Mfascia02 for muro 1 in saveTreeInfo
DEBUG:root:Found material Mmuro for muro 1 in saveTreeInfo
DEBUG:root:Found material Mquadra01 for muro 1 in saveTreeInfo
DEBUG:root:Found material Mquadra02 for muro 1 in saveTreeInfo
DEBUG:root:Found material Preview for muro 1 in saveTreeInfo
DEBUG:root:geometrygroup node created with 10 pins
DEBUG:root:total number of vertices = 18308, vertex indices = 70488, normals = 18308, uvs = 18851, uv indices = 70488, polygons = 17622
DEBUG:root:transferring actor Pantie : Hip geometry to octane
DEBUG:root: number of vertices = 1078, normals = 1078, uvs = 1078, polygons = 891, sets = 3564, texture sets = 3564
DEBUG:root:transferring actor Pantie : Right Thigh geometry to octane
DEBUG:root: number of vertices = 8135, normals = 8135, uvs = 8401, polygons = 7892, sets = 31568, texture sets = 31568
DEBUG:root:transferring actor Pantie : Left Thigh geometry to octane
DEBUG:root: number of vertices = 9095, normals = 9095, uvs = 9371, polygons = 8839, sets = 35356, texture sets = 35356
DEBUG:root: Mesh node for Pantie created
DEBUG:root:total number of vertices = 11623, vertex indices = 33478, normals = 11623, uvs = 11651, uv indices = 33478, polygons = 8370
DEBUG:root:transferring actor Hr-096 : hair geometry to octane
DEBUG:root: number of vertices = 10295, normals = 10295, uvs = 10322, polygons = 7342, sets = 29368, texture sets = 29368
DEBUG:root:transferring actor Hr-096 : cap geometry to octane
DEBUG:root: number of vertices = 1328, normals = 1328, uvs = 1328, polygons = 1028, sets = 4110, texture sets = 4110
DEBUG:root: Mesh node for Hr-096 created
DEBUG:root:total number of vertices = 24028, vertex indices = 92666, normals = 24028, uvs = 26303, uv indices = 92666, polygons = 23190
DEBUG:root:transferring actor V4EleganceSandals : Right Shin geometry to octane
DEBUG:root: number of vertices = 3237, normals = 3237, uvs = 3587, polygons = 3064, sets = 12215, texture sets = 12215
DEBUG:root:transferring actor V4EleganceSandals : Right Foot geometry to octane
DEBUG:root: number of vertices = 8777, normals = 8777, uvs = 9564, polygons = 8531, sets = 34118, texture sets = 34118
DEBUG:root:transferring actor V4EleganceSandals : Left Shin geometry to octane
DEBUG:root:transferring actor V4EleganceSandals : Left Foot geometry to octane
DEBUG:root: Mesh node for V4EleganceSandals created
DEBUG:root:total number of vertices = 23552, vertex indices = 87559, normals = 23552, uvs = 23440, uv indices = 87559, polygons = 22049
DEBUG:root:transferring actor Jacket : Abdomen geometry to octane
DEBUG:root: number of vertices = 7174, normals = 7174, uvs = 7124, polygons = 6590, sets = 26295, texture sets = 26295
DEBUG:root:transferring actor Jacket : Chest geometry to octane
DEBUG:root: number of vertices = 7714, normals = 7714, uvs = 7651, polygons = 7281, sets = 28910, texture sets = 28910
DEBUG:root:transferring actor Jacket : Right Collar geometry to octane
DEBUG:root: number of vertices = 3553, normals = 3553, uvs = 3553, polygons = 3404, sets = 13466, texture sets = 13466
DEBUG:root:transferring actor Jacket : Right Shoulder geometry to octane
DEBUG:root: number of vertices = 769, normals = 769, uvs = 769, polygons = 673, sets = 2674, texture sets = 2674
DEBUG:root:transferring actor Jacket : Left Collar geometry to octane
DEBUG:root: number of vertices = 3459, normals = 3459, uvs = 3459, polygons = 3307, sets = 13078, texture sets = 13078
DEBUG:root:transferring actor Jacket : Left Shoulder geometry to octane
DEBUG:root: number of vertices = 883, normals = 883, uvs = 883, polygons = 794, sets = 3136, texture sets = 3136
DEBUG:root: Mesh node for Jacket created
DEBUG:root:total number of vertices = 31191, vertex indices = 121926, normals = 31191, uvs = 32201, uv indices = 121926, polygons = 30498
DEBUG:root:transferring actor V4MiniBikiniTop : Abdomen geometry to octane
DEBUG:root: number of vertices = 3803, normals = 3803, uvs = 3944, polygons = 3734, sets = 14870, texture sets = 14870
DEBUG:root:transferring actor V4MiniBikiniTop : Chest geometry to octane
DEBUG:root: number of vertices = 23132, normals = 23132, uvs = 23867, polygons = 22636, sets = 90544, texture sets = 90544
DEBUG:root:transferring actor V4MiniBikiniTop : Neck geometry to octane
DEBUG:root: number of vertices = 4256, normals = 4256, uvs = 4389, polygons = 4128, sets = 16512, texture sets = 16512
DEBUG:root: Mesh node for V4MiniBikiniTop created
DEBUG:root:total number of vertices = 1280, vertex indices = 5120, normals = 1280, uvs = 1485, uv indices = 5120, polygons = 1280
DEBUG:root:transferring actor V4-AO6_Bracelet : Right Forearm geometry to octane
DEBUG:root: number of vertices = 1280, normals = 1280, uvs = 1484, polygons = 1280, sets = 5120, texture sets = 5120
DEBUG:root: Mesh node for V4-AO6_Bracelet created
DEBUG:root:total number of vertices = 441, vertex indices = 1600, normals = 441, uvs = 442, uv indices = 1600, polygons = 400
DEBUG:root:transferring actor GROUND geometry to octane
DEBUG:root: number of vertices = 441, normals = 441, uvs = 441, polygons = 400, sets = 1600, texture sets = 1600
DEBUG:root: Mesh node for GROUND created
DEBUG:root:total number of vertices = 12511, vertex indices = 49964, normals = 12511, uvs = 12007, uv indices = 49964, polygons = 12494
DEBUG:root:transferring actor muro geometry to octane
DEBUG:root: number of vertices = 12511, normals = 12511, uvs = 12006, polygons = 12494, sets = 49964, texture sets = 49964
DEBUG:root: Mesh node for muro created
DEBUG:root:transferring actor muro 1 geometry to octane
DEBUG:root: Mesh node for muro 1 created
DEBUG:root:Cuda Error : CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
RAM: 8 Gb
Windows 7 (64 bit)
Unfortunately the last line says it all "DEBUG:root:Cuda Error : CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.".
Whilst you will be able to render simple Poser scenes inside 1GB, you will need to ensure you monitor VRAM use very closely and reduce the size of large texturemaps. There is a script "Scene Texture Counter" that comes with the plugin which will tell you how much VRAM the Poser scene will use.
My main PC only has a 1GB card, and never found it a limiting factor, but I was also doing single figure scenes and got pretty good at squeezing a lot into a small VRAM space.
Hope that helps.
Kotoboy
Thank you for your patience ;)
RAM: 8 Gb
Windows 7 (64 bit)
Return to “Poser”
