Octane Plug 1.5 Trackback Error
morphious2013
Hello. Here is an error I am getting. Loaded Daz's Olympia G2F, created 2 light emitters in Poser. Initiated Octane Plugin, tried to change Kernal from Direct Light To Path Trace. Here is the error I got.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1374, in <lambda>
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1719, in comboBoxNodeType_SelectedIndexChanged
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1916, in MemoriseTreeState
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 1908, in MemoriseTreeState
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 2932, in displayError
ValueError: Error: null tree view in MemoriseTreeState for pin maxdepth
Have you followed th instructions at http://render.otoy.com/forum/viewtopic.php?f=45&t=37605 which read:
It is strongly recommended that you delete your default rendertarget settings (delete C:\Users\[username]\AppData\Roaming\Poser Pro\10\defaultrendertarget.por) and recreate them again in the plugin. This will ensure the new daylight structure is saved in your default rendertarget
Hopefully that should fix your error.
morphious2013
no such file exists on my computer. even did a file name search. could it be called something else? ugh.
randall.
morphious2013
I take it back. Funny, file search did not fiond anything. Manual search I found that file under Poser 9. In the Poser 10 folder, nothing. Still having same problem. Fire up plugin, and Kernal is defualt to direct lighting, change to Path Tracing, and get same Trackback error. Any ideas? I really need to solve this, losing time and money with this. Thanks for your help..
Randall.
Hi Randall - you'll need to get me some more info pls - like what version of the plugin are you running?
Also, does it happen with all scenes, just old scenes, or new scenes too?
Is it stopping you from rendering?
Does it happen only when the Viewport is open, or when both open and closed?
It possible your startup Poser scene has stored Octane values in it. If this is the case, Edit->General Preferences->Document tab->Launch to Factory scene.
morphious2013
OK, here is the info.
Plugin 1.5
It happens with all scenes, old, new.
It stops me from rendering, as I need to render in Pathtrace, not directlight.
It happens both, with viewport open/closed.
Also now getting Trackback errors when using HDRI in Texture Environment, when I try to rotate the HDRI, and also when I use just an RGB in texture environment node, when I try to adjust the colors. And that error won't let me close the color picker at all.
Poser Recently had an update, 3.1 I think. Does the Octane 1.5 plug need that update?
Hope this helps. Thanks.
Randall.
Randall, this sounds like a plugin installation issue. Is it possible Poser was running when you installed this update?
Can you pls try: Reboot, uninstall the plugin via the Windows Control Panel, re-download the 1.5 version of the plugin and then re-install.
Let me know how you go.
morphious2013
No, it was not on. I will delete, download, and re-install. I;ll let you know soon.
morphious2013
OK, still getting the errors. STRANGE thing is, if I open viewport, then close it, the errors stop, and I can change Kernal, text env colors, etc.
Randall - can you post the Octane Log (from the Devices Tab) after this error occurs pls? And also post the octaneplugin.log file.
Keen to find out why this is happening to just you.
Return to “Poser”
