Change node from "diffuse" to "glossy"
Forum for OctaneRender Lua scripting examples, discussion and support.
Namijr
Hi!
I know there was already a post with a similar question, but it really beats me :?
Here is the original thread: http://render.otoy.com/forum/viewtopic.php?f=73&t=37602
My problem:
I try to change a node from "Diffuse" to "Glossy", because the exporter of the DAZ Studio exports all materials as diffuse ones.
Here is my little piece of code, which does not work (in the output I can see that the type changed to "glossy"):
-- Get the selected mesh.
local mesh = octane.project.getSelection()[1]
assert(mesh:getProperties().type == octane.NT_GEO_MESH, "mesh expected")
local matNode = mesh:getConnectedNode('Torso')
if matNode then
print(string.format("material %s", matNode:getProperties().name))
matProps = matNode:getProperties()
-- change to glossy
matProps['type'] = octane.NT_MAT_GLOSSY
matNode:updateProperties(matProps)
octane.nodegraph.evaluate(matNode)
octane.changemanager.update()
print "---------- Properties ----------"
for key,value in pairs(matProps) do print(key,value) end
end
Any help or code snippet would be very appreciated :D
Thx,
Christian
grimm
Hi Christian,
The first problem I see with your script is this line here: :)
getConnectedNode does not work like this, but you can try this line instead:
local matNode = octane.nodegraph.findItemsByName(octane.project.getSceneGraph(), 'Torso', true)[1]
With this line you wouldn't need to get the selected mesh but it would also only find the first instance of any nodes named "Torso". Hope this helps.
Jason
Namijr
Hi Jason,
thank you for your code change, but it doesn't work as it should, I have changed it a little bit, so I have not to select the mesh anymore.
The problem seems to be that the only item in the SceneGraph is the mesh node?
My real problem is the following: I want to change the material node from "diffuse" to "glossy" directly in the original node.
Do you think this this possible, or do I have to create a new material node and connect this one to the "Torso" node?
Sorry for my english, I live in Austria and my native language is german ;)
Codechanges:
local sceneGraph = octane.project.getSceneGraph()
local meshNode = sceneGraph:findFirstNode(octane.NT_GEO_MESH)
local matNode = meshNode:getConnectedNode('Torso')
Bye,
Christian
PS: Oh boy, I hate it to be an absolute beginner :oops:
grimm
Hi Christian,
No problem. ;) I think there is an issue here as I'm not getting any results when I tested your code either. I was thinking it was because the node isn't being found but it appears that it's just not working. I'm still confused by the difference between these "internal" nodes and the "external" graph nodes. I have not been able to use any "internal" node and have only been able to get the "external" nodes to work. Maybe Thomas or another developer can comment and explain the difference to us. I tested this with Octane 1.51 and it didn't help. :?
Jason
Namijr
Oh man,
I am getting too old for this :lol:
Thank you for your help, I'll try to solve my problem with the external nodes.
Let's see how far I get ^^
Bye,
Christian
grimm
I have reviewed the posts that Thomas wrote on nodes, etc. The difference appears to be that a node can be either owned by a graph ("external") or by a pin ("internal"). I think your code is working, where the problem is, is another thing. Instead of getting the properties of the node, just do a setAttribute on it. In this case something like this:
matNode:setAttributes('type', octane.NT_MAT_GLOSSY, true)
Then do a change manager update and see if that works.
Jason
roeland
You can't change the type of a node after it's created. You can create a new node with the correct type, but then you get a node initialised with the default settings. The functions to replace nodes are not exposed in the LUA API yet.
Roeland
grimm
Ah, that explains it, thanks Roeland. :)
Namijr
Hi Roeland and Jason!
Thank you very much for the explanation and the help.
This forum ist really cool, and the members are so helpful :D
Christian
Zay
Is it possible now to replace nodes ? Got a 100's of materials where I like to change Diffuse to Glossy.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
Return to “Lua Scripting”
