Live DB
samhal
This morning, at about the time I settled down for some poser/octane time, my internet connection burped. I pressed on not knowing how things would work out...I was afraid the plugin would fail the authentication process, but it came up as usual. Live DB however would not initialize. Even when internet was restored, Live DB was down. Killing the plugin and relaunching it did not help. I had to kill poser and start from the begining for LiveDB to work again.
Anyway, is there anyway to move Live DB materials this into local stores to prevent this from happening? If my cable goes out for awhile, I'd still like the use of the materials.
Sam
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
Hi Sam
I have heard that the LiveDB does not re-initialise once the connection has failed. I will check this out. The materials "cache" now, so that they load quickly (if you have loaded them previously), but they still require an internet connection to access the "master list" - and that is probably not something that should be changed.
Return to “Poser”
