OctaneRender® for ArchiCAD 1.55 [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for ArchiCAD, build 1.50 onwards (STABLE RELEASE). This version is compiled against Octane 1.50, so see the requirements for that build regarding compatibility with your video card.
This version of the plugin runs on ArchiCAD 15, 16 and 17 - 64 bit.
Scenes saved with this build cannot be loaded with the 1.20 build, so make sure you keep a backup of the 1.20 scenes.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- ArchiCAD version (ArchiCAD -> Help -> License Information -> Version and Build Number
- OctaneRender for ArchiCAD version (ie. 1.02a)
- In the unlikely event of a crash, pls provide the dump report from the C:\Users\[username]\Graphisoft\BugReporting-[version] folder (on Win 7). Either post or email (to "paul at physicalc-software.com") the "ArchiCAD-XXXXXX-FATAL.RPT" file from this folder.
For more information...
- Read the on-line manual
- Read the FAQ
- Watch Tapperworks Showcase Part 1, Part 2 and Part 3
- Check the Facebook page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for ArchiCAD 17 1.55.0.12 (64 bit)
- OctaneRender for ArchiCAD 16 1.55.0.12 (64 bit)
- OctaneRender for ArchiCAD 15 1.55.0.12 (64 bit)
Garquitectos
Many thanks!
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
rappet
That is great. Many thanks :D
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
przemn
Thank you for archicad 16 version :)
Przemek
kxl
Hi Paul,
In the 1.52 standalone version they added vertical shift,
" Add option to the thin lens camera node, to keep vertical lines parallel."
it would be great if you cloud integrate this feauture to the archicad plugin :D
Thank you.
Stefan.
Windows 7, Intel Core i7 @3.40 GHz, 16 GB RAM, 2xGTX 580
I will do a build against 1.52 in the next day or two.
BfPuVAK
Hi Paul :)
I have often these problems:
- the 'Pause Rendering' button seems not to work properly. Especially at bigger scenes it has very often no effect, the viewport
is still actualised when moving cam in the Archicad-3D-viewport
- sometimes when editing (octane) materials or when loading one from the DB, the viewport refreshes but the changed material
stays without any change. Even pressing 'refreshing geometry/materials' doesn't help. I have to close/open the plugin, then
it will be actualised
The first one does have nothing to do with the last Octane/AC-plugin updates, but the second one is a new one i think.
Greetings,
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
Thanks Artur. If you have a scene which demonstrates the above problems, can you pls send it to me?
Regarding the issue where the imported material does not update in the Viewport, I have seen this in my other Octane plugins, and it was caused by changing the material types in a material mix - but I could not reproduce it in the ArchiCAD plugin. So if you can help identify to situation where this occurs, that will help be track down the problem.
I have refreshed the installers at the top of this thread with:
1.52.0.10
- Compiled against Octane 1.52 (adds PerspectiveCorrect pin on the Camera node)
kxl
Thank you Paul :D
