OctaneRender for Revit Beta 1.55 [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit 1.5 - STABLE RELEASE.
Revit Version
This version runs on Revit 2013, 2014 and 2015 on Windows XP, Vista, 7 and 8, 64 bit.
Nvidia Driver Version
This release requires Nvidia drivers 335.23 or later.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
For more information...
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Revit 2015 1.55.0.8 beta (64 bit)
- OctaneRender for Revit 2014 1.55.0.8 beta (64 bit)
- OctaneRender for Revit 2013 1.55.0.8 beta (64 bit)
Deleted.
JNDesign
Hi Face_Off
Silly question
Will Revit Plugin ver1.2 still work once I install 1.5??
Also do I need to install Octane stand Alone as well if I am only using the revit plugin?
Last question, do you know how far is Octane Cloud render plugin for Revit
Sorry for all these silly ones mate.
cheers
Not sure of what you are installing of version 1.5. If you install the plugin version 1.5 over the plugin version 1.2, you will get the plugin running in Revit at version 1.5. 1.2 will no longer be installed. Scenes saved with plugin version 1.5 will not load in plugin version 1.2.
Whilst it is not mandatory, it is a good idea to update Octane Standalone to 1.5 if you are updating the plugin to 1.5.
There are a few ways to do this - but in summary, load your scene into the Revit plugin, start rendering, then "Export Scene to OCS". The next version will allow you to save as ORBX (rather than OCS), which you should do - the exported ORBX file can be uploaded to an Octane Amazon Cloud AMI instance - where you can render it. If you want to try this, let me know and I'll add the ORBX export option to the plugin for you to try.
JNDesign
thanks Paul
So I take it that ver 1.5 is ready for production use?
also is there a feature list for this version of the plugin?
best
Yes.
http://render.otoy.com/forum/viewtopic.php?f=61&t=37775 contains the majority of changes. In summary, new projection nodes (awesome for Revit materials where you cannot re-UV meshes), better error logging, more user friendly node names, export to Standalone (via OCS or ORBX), checking for missing texturemaps,
many other minor Octane 1.5 specific changes.
Camera motion blur and export to ORBX (cloud render format) should be in the next release.
prehabitat
Woot! looking forward to motion blur - while I still do most of my projects in Revit (just playing with Rhino & doing my landscape plans in it till I get my head around it enough to use in production)*
*that said; the materials in Rhino are a dream compared to Revit...
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
JNDesign
pls disregard
timbarnes
Does the plugin work with Design Options? I'm seeing the wrong geometry show up in the Octane window when I try to render design options.
Here's the scenario - a single model for concept design, multiple design options for alternative lobby treatments. I want to render out a view of each option...it doesn't seem to work correctly.
tim
Mac Pro 3,1 / Lion / 14G RAM / ATI HD 2600 / nVidia GTX 470
i5-750 / Windows 7 Pro 64bit / 8G RAM / Quadro FX 580
Revit 2011, SketchUp 8, Rhino
HI Tim. The Revit 2012/13 version of the plugin convert the raw Revit scene items to geometry as best it can. It's possible that the Design Options are not converting to geometry correctly (and I don't recall that being tested during the closed beta stage). The Revit 2014 version of the plugin has an entirely new geometry loader, where it gets the raw scene geometry vertices, polygons, etc form the Revit API and is both quicker and more accurate - so if at all possible, I would recommend using Revit 2014 if you can. If Revit 2014 is not an option, pls send me a sample scene which demonstrates the issue you are having with Revit 2012/13 and I will look into it.
Return to “Autodesk Revit”
