Hello, I've found a problem in Maya 2014 with the Octane Light where if it is a sphere it doesn't work correctly. It works correctly in Maya 2013. And it works fine as a plane but it doesn't emit light as sphere.
Here is a picture of the problem:
http://i.imgur.com/R5NROfa.jpg
Thank you
Maya 14' Light node as sphere does not emit light
See if the situation improves if you turn on alpha shadows on the render globals and set the light opacity to 0. Boost it's power just to make sure.
http://render.otoy.com/forum/viewtopic. ... 80#p165180
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
