This is such a noob question but haven't been able to find an answer to it (manual, search, etc)....probably right in front of my face.
So, I'm working away on a material (using the material ball) and trying some new ideas. Get to a point where I like it and I want to save the material....let's say a Mix material. In the graphic window and right click to save. I hit save and the Store items UI comes up and I save the package to my hard-drive and name it. But, when I try to bring the material in only the mix material element comes in without any of the settings or materials which were assigned to it initially.
How do I save a material to my hard drive?
TIA
Saving a material?
Are you saving the macro?
I haven't tried this, but based on the results, it sounds like you are saving a diffuse material that has nodes attached to it instead of a macro that contains your aterial and all the pins inside.
if this is for 1.5, group them together and then save.
