OctaneRender™ for Blender 1.50 - 4.3 beta Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • New 1.50 engine.
  • Blender version 2.70.
  • Bug fixes...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v4.3 beta Linux (115MB autoinstaller file)
grimm
Yay!! But blender will not run. :(
jason@gemong OctaneBlender$ ./blender
./blender: error while loading shared libraries: libboost_filesystem.so.1.51.0: cannot open shared object file: No such file or directory
I have libboost_filesystem.so.1.54.0 already installed so I'm not sure why it couldn't find it?
I don't know if it's another problem or if it will be fixed once Blender is running, but I also get this error from OctaneServer:
jason@gemong bin$ ./OctaneServer
OctaneServer v. 4.3
Octane: ERROR reading Octane license data
Octane: no active license found
Thanks, looking forward to playing around with the new version.
Jason
grimm wrote:I have libboost_filesystem.so.1.54.0 already installed so I'm not sure why it couldn't find it?
You can use Blender's install_deps.sh script if you need.
grimm wrote:I don't know if it's another problem or if it will be fixed once Blender is running, but I also get this error from OctaneServer:
OctaneServer v. 4.3
Just enter the license info from inside Blender again, and that's it.
grimm
Thanks Jimstar,
It didn't help, same error. :( I tried to link the old version to the new one but it didn't help either. I don't have any problem running 2.7 from the Blender web site. Is it a static compile error?
Jason
grimm wrote:It didn't help, same error.
What does mean "didn't help"? What did you do? Do you have now the 1.51 libs installed and available in your system?
grimm wrote:I tried to link the old version to the new one but it didn't help either. I don't have any problem running 2.7 from the Blender web site. Is it a static compile error?
No, this is not the plugin's error. It is exactly how Blender's install_deps.sh script works - I did not change anything in 2.70 Blender release regarding this. Moreover, starting from this 2.70 I just stopped to fight with its static linkage bugs and patching this script in every release - now I just use the plain version of this script how it is given by Blender developers.
And taking into account I build this special version of Blender itself against all static versions of boost libraries - it seems that this Blender's dependency installing script just builds some of dependency-libraries dynamically linked against boost...
Why do you not have this problem with "stock" 2.70?.. May be different reasons: Blender developers may not use their own install_deps.sh script when building the releases (and use some especially prepared set of patched and statically linked libraries), or more likely some features (the libraries for which this script builds dynamically linked to boost) may be disabled in "stock" build... As in these builds I enable as much features, as possible, to not get here again the complaints "why is it disabled?"...
grimm
Ah, that might explain it. I think I did see a post on the boost library issues, maybe that's the problem? I don't remember where I saw that, I can check around and see if I can find it.
grimm
I can't find now. :( I will keep looking, it's bound to pop up somewhere. :?
mib2berlin
Hi grimm, try to make a symlink called lib.1.51 to your 1.54 lib, should work.
I am not testing this.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
bluerocket
Thanks Mr J
I'll try later
Regards
MC
Asus Rampage IV Extreme | i7-3930K | 32GB | 2x GTX TITAN | 2x GTX670 4Gb | Win 64x
Return to “Blender”
