Worksession renders?
simsy73
Is it possible to render with octane using worksessions?
When I have tried, the only geometry visible in the octane viewport is the active model. All referenced models are invisible?
Can I control which references are visible in the octane viewport?
I haven't tried this yet. Let me investgate and get back to you afer the weekend.
I have looked into rendering in Worksessions - and at this stage the plugin does not support this. I have escalated this to McNeel to see if there is a solution.
simsy73
thanks for looking into it
I have been able to get Worksessions supported in the plugin (with McNeel help). Can you pls try the plugin version at http://render.otoy.com/customerdownload ... _64bit.exe. You will need Rhino SR8.
1.50.0.16
- Added support for Worksessions. Attached scenes will need their Octane materials already defined (ie. you cannot edit the Octane material of an attached scene object in the worksession).
Return to “Rhinoceros 3D”
