octane and visibility
matttrebor
Octane works fine with the visibility slider.
But per exemple when I have 2 boxes at the same position (and same size) with the visibility set to 0 to one box, it generate some bugs.
Here is an exemple :
I encounter this problem when I use Rayfire per exemple, because it generate a prefragmented object.
Karba
matttrebor wrote:Octane works fine with the visibility slider.
Coplanar polygons are always a bad idea.
Return to “Autodesk 3Ds Max”
