Specular Reflection Wrong?
treddie
Maybe it's just me, but the "4" and the "5" reflections appear way too dark to me. The "3" seems correct.
This is using v1.36
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
TRRazor
If you're looking at the reflection of "3" you'll surely have noted, that it is "hovering" over a brighter "background" than "4" and "5". Since those two are in the more shadowy area cast by the clocks housing the reflection is also darker.
Not a problem with Octane but actually a problem with reality ^^.
Try readjusting the light a notch down (if that is a possibility) so the reflections of 4 and 5 will be over the "non-shadow"-area of the face.
Hope this helps :)
treddie
TRRazor, I'm not so sure. Check out this comparison between the darkness behind the refracted 3 and 4. They are virtually identical.
Refracted 3 and 4.jpg (85.95 KiB) Viewed 3513 times
krzychuc4d
It really looks bad.
I always struggle with glass in Octane.
Sometimes Octane captures wrong reflection like yours and other time
glass looks too dark even if environment is bright.
Octane sometimes should be more "idiot proof"
My suggestion is to select glass object and change it shading angle to very low value,
I'm Cinema4D user and I'm not sure how this works in other software than cinema
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
treddie
I'm C4D, too, but I use Octane standalone. I'll experiment with what you suggested when I can free up my GPUs, and see what happens.
Are you referring to Phong shading angle?
boris
for me this looks more like a projection if I consider the positions of the numbers on the glass.
anyway, why should there be a reflection on the glass of something behind it?
sorry maybe I am totally wrong but I just starred at your image for 3 minutes and just did not understood it.
have you checked normals?
I sometimes get confusing results with glass having flipped normals after attaching mirrored geometry to a 3ds max poly (annoying bug).
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
treddie
Yah, I would expect double reflections of objects in front of the glass but not behind it...I have a glass table here in front of me and there are absolutely no double reflections for anything I place right underneath it, at any incidence angle.
My normals are correct. Just checked.
cakeller98
Can you export the model to octane, and post it? or just export the relevant snippet?
As of 2019-02-12
- Dell Precision 7710 w/Xeon E3-1535M v5 2.9GHz
- Windows 7 Pro, 64-bit (SP 1)
- 32 GB System Memory
- nVidia Quadro M5000M (Driver Ver 416.78)
- Standalone 4.0, 4.01.1, 4.02
- Maya 2018, 2019
Modo 12
Sketchup 2018, 2019
treddie
Come to think of it, I think the reflection of something under the glass is theoretically correct according to the Law of Reflection, but I think it is generally very very subtle. I think the idea behind it is that the image of those numbers is cast up onto the first and second surfaces of the glass, getting partially reflected and refracted both times to a degree depending on the incidence angle. So the image of the numbers reflecting off the first surface simply bounce back down and attenuate very quickly. But that portion of those very same rays that make it through the first surface of glass then collide with the second surface of glass and again, part is reflected back into the glass and part passes through it to our eyes. So now again, the very weak portion of the light that reflected off the second surface now both partially bounces off the first surface again and passes through the second surface towards our eyes as the second image of the numbers, with the remainder passing through the first surface back towards the bottom. So, light is reflecting back and forth zillions of times, getting weaker with each pass. So we would be lucky to catch the first reflection off the first glass surface, let alone any further reflections.
So I think the problem in Octane is that those glass reflections of what is underneath the glass are WAY too pronounced. My feeling is that the light rays that make the reflections aren't decaying nearly as rapidly as they should.
Olitech
treddie wrote:Come to think of it, I think the reflection of something under the glass is theoretically correct according to the Law of Reflection, but I think it is generally very very subtle. I think the idea behind it is that the image of those numbers is cast up onto the first and second surfaces of the glass, getting partially reflected and refracted both times to a degree depending on the incidence angle. So the image of the numbers reflecting off the first surface simply bounce back down and attenuate very quickly. But that portion of those very same rays that make it through the first surface of glass then collide with the second surface of glass and again, part is reflected back into the glass and part passes through it to our eyes. So now again, the very weak portion of the light that reflected off the second surface now both partially bounces off the first surface again and passes through the second surface towards our eyes as the second image of the numbers, with the remainder passing through the first surface back towards the bottom. So, light is reflecting back and forth zillions of times, getting weaker with each pass. So we would be lucky to catch the first reflection off the first glass surface, let alone any further reflections.
Interesting. Do you think this is because Octane glass does not contain a fresnel falloff?
I've also noticed that if I reduce the 'Opacity' parameter on specular materials, I keep getting double reflections...
Best,
O
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
