Photo match
Jorgensen
Hi
I'm trying to figure out how to create a photo match, but I can't figure it out :-/
I have set an octane material as environment map, but this means that the background goes around, but the model stays in place when i look around.
I thought that I could add an fixed image and set the render output to the background resolution of the image, and then move the camera to match the position in the photo.
Can anyone explain the right workflow?
Karba
Jorgensen wrote:Hi
Hi
Use 3ds max viewport with image background
mbetke
I set up a viewport background image, set it to render output. Then I use the perspective match tool from 3dsmax 2014 and fiddle around until it matches the perspective and render.
In Photoshop I merge the images and do some color-correction.
PURE3D Visualisierungen
Jorgensen
hi
thanks to you both :-)
Return to “Autodesk 3Ds Max”
