RepathOCS script
TIG
(c) TIG 2010
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided that the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
___________________________________________________________________________
repathocs.rb >>> ../Plugins/ folder
Description:
This repaths the textures within an Octane OCS file to match the current
OCS's folder.
It is to use in conjunction with Sketchup Octane Exporter if you have copied
an ocs.
For example you have a folder ../projectA/ containing 'project.ocs' with its
texture files in ../projectA/project_Textures/.
You make adjustments to the materials etc in the OCS.
Later you decide to do some parallel options...
You make a copy of the whole 'projectA' folder and its contents as
../projectB/
Because the paths to the textures are 'hardwired' into an OCS file the
'projectB' version of the OCS continues to look at the textures in
To separate the two OCSs completely you need to change the textures'
paths in the new OCS - you can re-map them manually but if there are several
files it's a pain.
The .obj can also be wrongly linked.
This tool does it automatically for you.
Copy the files and then run this tool prior to exporting the skp to the ocs...
Usage:
Open the Ruby Console and type
repathocs
+ <enter>
It runs and opens a browser to find the OCS to repath.
Select the OCS.
It is then edited to repath every texture to the
OCs's folder + /project_Textures/ folder.
So for example if the original points to
but the OCS is now in
'C:\Users\TIG\Documents\TesterB\'
the texture path will change to
The .obj file's is also renamed and its path corrected if necessary.
On completion it reports what's changed.
Note: If "_Textures" is different in your locale edit it below***.
Donations:
by PayPal to info @ revitrev.org
Version:
1.0 20101008 First Issue.
Unzip the .rb file and put it into your ../Plugins/ folder...
repathocs.zip
(2.05 KiB) Downloaded 371 times
TIG
bmneu
Wow, thank you! I will have to work with this and figure it out. I am so ignorant on everything and can't make sense of it.... little sleep, deadline this friday ugh. I've put trying to get this file to work the way it should aside and am doing it the hard way lol for now.
Core i7 X980 3.33GHz
12 GB RAM
GeForce GTX 480
Return to “SketchUp”
