Rendering with perspective turned off
Moderator: BK
Jazbee
Hi
Can't use Octane to render anything with perspective turned off in camera settings. OC viewport goes black the moment I click to disable perspective. I tried turning all camera functions on and off to see if it helps, but it doesn't. This happens in both 1.0 and 1.2 versions of the plugin.
Has anyone been able to successfully make Octane render without perspective? If no, is there a technical reason why that's not possible (that's a question to t_3)?
Thanks!
2x RTX 2080ti, AMD Ryzen Threadripper 1920X, 128GB RAM, Win10 Pro 64, Dual Monitor Setup
t_3
mh, yes, there seems to be a bug; probably nothing complicated, since the standard top/front/right/etc orthographic cameras still work as expected. expect to see this fixed in the next update...
Return to “DAZ Studio”
