octane poser plugin will not animate
spartan00j
my octane poser plugin will not animate. when i hit the render animation button it renders in the viewport once and thats all. plus nothing show up for the elapsed time estimated total time and average time per frame. and i get the manage.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\ViewportForm.py", line 717, in on_timer
WindowsError: exception: access violation writing 0x00000000000001B8
Hi - can you provide the info requested in http://render.otoy.com/forum/viewtopic.php?f=45&t=38577 under the section "If you have a support issue, pls provide the following information". And could you also provide a screenshot of the plugin Animation tab with the settings you are using. Thanks
spartan00j
I figured out what the problem was. I had (Maximum render time per frame (seconds)) set to 1
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Return to “Poser”
