Feature Request - Extract Input Node
cakeller98
When in a Node Graph, I'd like to be able to right click on an object from within a node and pull it out into a higher level.
As is I have to create an input node, connect it where the node I want to extract is, then cut the original node, then go to the parent node, paste the original node, and then connect it up.
It'd be sweet if by a single right-click action I could click on an item (or many) and have them pushed up to the parent node, and connected.
it'd be like selectively ungrouping.
As of 2019-02-12
- Dell Precision 7710 w/Xeon E3-1535M v5 2.9GHz
- Windows 7 Pro, 64-bit (SP 1)
- 32 GB System Memory
- nVidia Quadro M5000M (Driver Ver 416.78)
- Standalone 4.0, 4.01.1, 4.02
- Maya 2018, 2019
Modo 12
Sketchup 2018, 2019
manalokos
Expanding and colapsing nodes inside nodes could be a good thing and further simplify a tree.
A node with port that has a group inside could be reddish or with the color of the group itself.
cakeller98
Working with nodes more and more, and loving them! However, as I use them more and more, I'm finding a few things about the workflow tedious.
Internal nodes (nodes that are part of a material or whatever that don't show as a node in the node graph, but rather as a solid dot on the node:
I would like to be able to show those in the graph editor without having to copy, paste, and re-connect.
And the converse. I would like to be able to flatten a node network into a single node. IOW - say I have a clean material that i want to collapse down to only required (shared) nodes, and have the rest collapse into the highest parent node. Basically for all nodes that aren't shared, I should very much like to be able to collapse, or flatten/consume, them into their parent node.
As of 2019-02-12
- Maya 2018, 2019
Modo 12
Sketchup 2018, 2019
