I have asked myself if the following scenario is possible. Actually I couldn't test it. But maybe someone has it or knows how it works exactly.
Actual Setup:
I have 2 GPU cards with 3 GB VRAM. On the GPU-0 are 4 monitors so this card has less VRAM as GPU-1. If I want to render on both cards with Octane I have only 1,8 GB VRAM free. This counts for all additional cards I am using this way.
If I turn off the GPU-0 and only use the second one I have 2,8 GB VRAM free. So far so good and understandable.
Possible Setup:
What if I exchange the first card (GPU-0) with a Titan with 6 GB of VRAM. Than the Setup is GPU-0 = Titan with 6 GB VRAM; GPU-1 GTX 780 ti with 3 GB VRAM. Do I have 2,8 GB of VRAM available when using both cards together?
VRAM Issue with GPU-0 turned on/off
- BorisGoreta
- Contact:
You are correct.
Hi Tommes,
I can confirm this.
The limit will be the smallest, in this case the smallest will be the 780 ti. (unless for some reason your OS + other software starts eating up more than 3.2GB of the Titan's VRAM, at which point it will become the limitation...)
Chris.
I can confirm this.
Chris.
I have updated my System with one Titan as GPU card 0 for my monitors and the other 4 cards are GTX 780 ti. And I can confirm that now all (2,8 GB) of the available VRAM of the 780ti(s) is available
Actually I could recommend this kind of setup if you want to use the main display card for rendering, too.
Win 8.1 x64 | Supermicro dual 8-core XEONs | 128 GB RAM | 1 x nVidia Titan | 4 x nVidia GTX 780ti
