Hey, Joe.
Don't get scared building Your own rig. It's not so hard. A lot of us came from architecture/design/art backgrounds & get some knowledge 'bout pc's simply because we need good value & knowing that even if something messed up, we can fastly change a part or so without to much of worying.
BOXX are good - You pay extra, & get soemone on the line if something happens. However even with Your own build it's almsot the same - You can get anyone - even a geeky friend to help You out. technically these BOXX (or other boutique builds) are nothing special, they just use good parts that fit & that's all.
If You will be lookin' to path of trying to fit a rig on Your own steps to folow migh be:
* choose a CPU (let's say Core
i7-4930K ) k means OverClock'able [~500$]
* find a compatible mobo in this case Socket 2011 (what I see
ASUS &
Gigabyte is common picks) [200-400$]
* choose amount of RAM [64GB will set You back about 500-600$]
* If You're lookin' for OC, don't go too far, 'cos You'll end up messing with stability & get diminishing returns. However let's say before mentioned piece should be completelly fine with 4+Ghz, just choose good cooling. I'd recomend
AIO route - here's a good article to compare what's on the market [100-150$]
* Depending on You mobo & cooling solution, start looking for a case. Personally I love
Fractal Design, but there are a lot of other good case that will fit Your taste & needs. Just keep in mind that You need it to be compatible with chosen cooler (mounting space) & providing enough airflow if You go for multiple cards one day. [100-300$]
* last but not least - PSU. depending on what cards You have or how much possible expansions slots - choose it wisely, so You don't have to change it if You want to add extra card later [price ?]
* as for GPU I'd go for TitanBlack & then look..You can always try - if it's too limited You can take it back and get PRO (quadro) card however for GPU renderers like Octane Titan is a best deal in terms of speed and available memory.
* for SSD's my personal preference would be
SAMSUNG or
Sandisk as they do manufacture those not only rebrand & resell.. [again, depends on Your chosen product..]
With this route You'd end up having OCed 6core in with Silent Cooling for stable working in a neat case with best GPU for rendering, few extra slots for upgrade if needed. If You start cuting corners You'll sacrifice something : performance or reliability. So choose parts acording to Your needs.
As for asembling the rig itself - it's quite fun & it will take and evening at most, even if You haven't ever done that - just follow instructions (mounting procesor, ram onboard, putting it in the case, adding cooler, GPU, PSU, conecting drives, pluging some wires & You're ready to go =) choose an operating system - isntalation doesn't take to long usualy. (You migh have to flash bios to for that You'll probably need usb key) download some letest drivers as in the box will probably be out-dated. & You can start instaling software =)..
