OctaneRender® for Maya® 1.33 - 2.3 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed "Border mode" bug in image textures.
  • Fixed "Power" attribute of texture environment.
  • Obsolete rotation attribute removed from texture environment.
DOWNLOAD
OctaneRender for Maya 1.33 - 2.3 (27.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
dionysiusmarquis
Don't know since when it's implemented but the reshapable proxy ist really nice! Its quite fun to finally see dynamics like nCloth changing and shaping directly in the render view without caching.
solomon
the hdri power option is fixed. a quick question, how do we rotate the hdri now since that option was rendered obsolete?
Solomon W. Jagwe
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
dionysiusmarquis
there is a slot named Transform in your Texture node. just connect a Full Transform or just Rotation Transform node I think
nedan
Camera settings are not obeying parameters from Film Back section like: Pre Scale, Post Scale or the Render Pan Zoom button. Will be helpful if this will be fixed. Thanks.
ciboulot
Hello everyone.
Special thanks to Jimstar for the hard work he did.
I don't have time currently to test the 1.33, but I already have some questions:
1. Is the object/shadow visibility function implemented in this version?
2. The shaders and the pipeline we developped are going to work with this one? I heard that the shaders are going mad because of changes in the node system.
3. Will the renderlayers work? Because I still have a lot of problems with them when rendering animation scenes which contains renderlayers. e.g, the rendering engine doesn't update when changing rendering layers (although it was checked with the layer override settings).
Thanks for the reply.
Cheers
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
TBFX
Hi JimStar,
While replying to another post I just checked and realized that we now have a phase attribute on the scattering medium node but after testing it doesn't appear to be doing anything yet. Is it supposed to?
T.
tailorstore
Two things really.
First of all, I haven't been able to load any Maya plug-in since 1.5 in Maya 2012 (yet I've tried on two different computers) however the same installation works well in 2014, so if Maya 2012 is'nt supported you shouldn't list it as such.
Second, will support be added to implement older node behavious/connections in future releases? Is that something that's being worked on? Because I had spent some time setting up a couple of pretty complex shaders and we've been working on integrating them into our scripting pipeline, when suddenly I install 2.0 and things are.. Pretty broken..
/Robin
Digitaline
Hi all,
i can't install on maya 2012 since 1.20 1.5 too. It works on maya 2014 but the mayabatch is buggy.
When you launch an animation you'll have skipped or buggy frames.
Unusable for animation !
tailorstore
Not that I'm expecting an answer, because customer support doesn't seem to be prioratized, but.. Is there some way to scale textures based on number of repetitions, like normal (as before)? Because the new transform-node(s) use scale, which isn't really optimal when I have a small tile I need to repeat specifically 30 times.
Return to “Autodesk Maya”
