OctaneRender® for Maya® 1.33 - 2.2 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixes in Octane Alembic export (thanks TBFX).
  • Minor bugfixes...
DOWNLOAD
OctaneRender for Maya 1.33 - 2.2 (27.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar,
Alembic export all seems good now. Are we heading for a time in the future when we will be able to export a .ocs and an alembic file that will all load up in the standalone with all shaders and environment intact? Because that would be AWESOME!
Texture placements now work however the border modes are mapped incorrectly. Current mapping as follows.
Wrap -> Wrap
Mirror -> Black
Black -> White
White -> Clamp
Clamp -> Mirror
Also I see now to rotate an environment texture we need to attach a spherical projection to the file node and a transform to that projection. It makes sense given the changes to the engine and is far more useful than the simple rotate we had before but perhaps we should remove the rotation input fields from the texture environment node to avoid confusion.
The power attribute still has no effect on a texture environment but certainly works on the sky env.
Trev.
TBFX wrote:Alembic export all seems good now. Are we heading for a time in the future when we will be able to export a .ocs and an alembic file that will all load up in the standalone with all shaders and environment intact? Because that would be AWESOME!
I think it is rather the question for standalone threads...;) The plugin's features depend on it...
TBFX wrote:Texture placements now work however the border modes are mapped incorrectly. Current mapping as follows.
Wrap -> Wrap
Mirror -> Black
Black -> White
White -> Clamp
Clamp -> Mirror
Trev.
Thank you, will be fixed in next version.;)
Next version HERE.;)
Return to “Autodesk Maya”
