OctaneRender® for Maya® 1.33 - 2.1 Win [OBSOLETE]
This is the test release
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed Diffuse material and Color Correct texture bugs (thanks TBFX).
  • New 1.33 engine.
  • Added new feature: export of animation into OctaneRender Alembic file. The feature is implemented in the first draft, so you can test it...
    All animation modes which are implemented in this plugin should work: so e.g. if you will export "Camera only" animation, the size of alembic file will be much less than in other modes. If you will export "Movable proxies" animation with just a few "movable" objects - the size will be less than when exporting "Full" animation mode of the same scene...
    Only geometry and camera export is supported so far. Materials, imager, environment etc are not supported at this time, but you can tune them in standalone after export.
DOWNLOAD
OctaneRender for Maya 1.33 - 2.1 (27.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar! Will test soon.
T.
danimatrix
the options of hdr don't work. (power, rotation ecc..)
maya 2014 64
p.s sorry for my english
TBFX
Hi JimStar,
So far using your OctaneRender alembic export I have only managed to get one very simple scene to export as alembic to the standalone correctly. Every other scene I have tried gets the camera but no geo (the alembic node has no geometry pin when loaded into the standalone)
I will PM you a scene. The scene exports to alembic as expected if I just use Mayas default alembic export but exports incorrectly as stated above if I use the OctaneRender alembic export option.
T.
solomon
danimatrix wrote:the options of hdr don't work. (power, rotation ecc..)
maya 2014 64
same here, the powere options for hdri for the texture environment is not working ~ I had to resort to using the Exposure instead.
older scenes are loading very dark in this new build.
Solomon W. Jagwe
TBFX
Confirmed here too. In fact I haven't been able to get texture transformations working at all in this version, or any of the new projection methods, though I could just be missing something. Has anyone else had any luck with these?
JimStar wrote:Fixed Diffuse material and Color Correct texture bugs
It seems new diffuse materials created in this version work now but legacy diffuse materials are still not recognised and are converted to gray.
Color Correct is working, thanks.
T.
Next version HERE.;)
Return to “Autodesk Maya”
