OcDS UPDATE v1.2.120.3430
Moderator: BK
t_3
this is an update to for any version past and including build .3410
it's probably going to be called the "crashes-be-gone-edition" (yet to be proven true ;))
NOTES
the new versions .3410 and .3413 did use multithreaded materials and textures processing. unfortunately there is no way to make that work reliably for the majority of users, so this is now finally dumped.
the good thing: the plugin won't work notably slower because of that, nor does this notably increase the time to load materials.
the bad thing: the plugin will block the studio ui when processing quantities of maps; until now you could work in studio while the plugin was processing stuff in background - this is no longer possible. if you don't plan to work with the plugin right away you may want to turn auto mats off, to save a bunch of seconds extra waiting.
note: if you don't have the plugin pane open all the time, you will of course only notice that because the ui is blocked; i'll add an additional progress popup for this case in a next version.
btw, there is an action (usually in the render menu), that you may ideally also place into a toolbar (to have it at hand quickly), it is called "OctaneRender Materials":
it toggles between:
- full auto mode ... the plugin creates/deletes octane materials whenever the scene content changes
- manual mode ... the plugin doesn't catch up to content changes by itself, instead you need to use the "missing" button in the mat tab to create oc mats for changed contents
- .duf only ... the plugin doesn't create octane materials automatically, but will still load new oc mats from saved .duf contents (if there are any embedded).
FIXES
  • the plugin should no longer block daz render settings dimension/ar adjustments, as long the octane vp is closed
  • fixed mismatched vram size display when usage is > max. available vram (hopefully)
  • fixed wrong auto-rayepsilon updates when changing render settings
  • fixed wrong auto-rayepsilon updates when resizing the viewport
  • non-standard daz materials should no longer receive a zero opacity (hopefully)
  • fixed a bug causing no oc mats to be created for content entirely loaded before the plugin is fully initialised
  • fixed explicit unlinking oc mats not working when done from within the oc mat tree
  • emitters are correctly placed into the emitters group when loaded (scene + preset)
  • recalling recent folders (as well as maps) in the image menu will work for long folder names/paths
  • removed mistakenly multiplied entries in the image menu (for the scene objects sub menus)
  • the locked viewport when having a scene with no oc mats and no camera should be resolved
  • saving a scene with unlinked daz surfaces will no longer freeze ds
  • removed wrong node type selector when switching from *.* to a value node in the nge
  • fixed a bug causing orphan render settings/environment entries after loading a scene
  • fixed a bug that caused a render restart when switching between the render settings/environments tabs
  • fixed a bug causing render settings and environments to be randomly selected after loading a scene;
    note: this is only completely solved after re-saving a scene saved with an older version.
  • fixed a bug causing the post processing state to be not saved with the scene
FEATURES
  • added an "unlinked only" filter to the daz surfaces tree filter box
  • added another keyboard shortcut: ctrl-shift-u to unlink currently selected oc materials
KNOWN ISSUES
  • preview rendering is temporarily turned off to find a better method for rendering preview updates in background (as this was causing issues in the nge).
  • when having the nge (or main plugin pane) floating, the image preview might shift the active window state in a way the floating pane gets hidden behind other panes; could not clearly reproduce this yet.
  • under some circumstances scene contents are duplicated each time a scene is loaded again - if this happens to you, pls drop me a note as i currently only have 2 reports about that, and no definitive single reason why it happens; most probably when loading a full scene with the content browser (you may try file > open instead) but it might also have other reasons yet to be found out.
  • if i didn't catch up with a particular issue, or if you still have some issues that you had reported already - pls report back once again... thanks!
CHANGE HISTORY GET IT!
The obvious is that which is never seen until someone expresses it simply
sqjam
Thanks! Stability - is basic.
Laticis
Thank heaps :)
vortex3d
I'm getting a notice that v.3431 is available today after updating to v1.2.120.3430 yesterday. I can't find it anywhere! =/
Is this a typo or is there really a 3431 version?
Win 8.1 Pro 64bit | GTX 660Ti, GTX TITAN, 6GB GDDR5 | Intel Core i7 3970x, 3.5 GHz | ASUS P9X79WS | 64GB RAM
LuvMultimedia
I installed this and now DAZ just keeps crashing. I officially cannot even use octane now--every time I load a scene it crashes. Been trying since 10 PM to make the damn thing work to no avail--it is now 8 AM EST. when it doesn't crash it locks up or won't load a texture. I am not doing anything different in fact--I can't even load scenes that were working fine before--is there a way to UNISTALL this patch?????
Alicia
WIN 10 64 | Geforce 970| 16 GB
t_3
LuvMultimedia wrote:I installed this and now DAZ just keeps crashing. I officially cannot even use octane now--every time I load a scene it crashes. Been trying since 10 PM to make the damn thing work to no avail--it is now 8 AM EST. when it doesn't crash it locks up or won't load a texture. I am not doing anything different in fact--I can't even load scenes that were working fine before--is there a way to UNISTALL this patch?????
Alicia
makes me very unhappy to hear that. you can just use the updater from the last version to revert the update. can you help me to find out why this happens? i expect to find a particular reason which can be sorted out rather quickly... if so pls send me a pm!
t_3
vortex3d wrote:I'm getting a notice that v.3431 is available today after updating to v1.2.120.3430 yesterday. I can't find it anywhere! =/
ah, oh; this is a typo in the version number on the server. is corrected...
t_3
LuvMultimedia wrote:Been trying since 10 PM to make the damn thing work to no avail--it is now 8 AM EST.
and pls, as soon you have problems, post or drop me a pm - i'm here to help asap...
bluerocket
Thanks t_3 ;)
Regards
Asus Rampage IV Extreme | i7-3930K | 32GB | 2x GTX TITAN | 2x GTX670 4Gb | Win 64x
vortex3d
I just wanted to say that I own Poser and 3DSMax plugins as well and this version (Daz3D) is by far the most aesthetically pleasing, user friendly and fastest of them three. Outstanding work from the DS team! :D
Return to “DAZ Studio”
