Hi all
I am having a hard tiem moving/pointign IES lights with the new plug in. I am setting the distribution node to image, then using the transform / rotation pins but i cant get the light to move other than very eratic movment using Z access.
I ahve tried changing the rotation order but again get odd results and little to no controll on where I would like the light pointed.
Is there a undocumented way to accomplish this? The curent stable cersion works well with manipulating the direction of light, the test build not so much unless something has changed on how we should do this?
thanks
IES movemtn with latest plug in build
Dissreguard......
Figured out to change projection to Spherical and use that rotation ....
sorry :-/
sorry :-/
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
