Reception WIP
glimpse
4th & probably the last step in this WIP (as I'm putting this personal project aside to dust for a while =)
Main focus of this test wasn't to render best lookin' presentation or putting insane amount of details.The aim was to get mood, more or less out of the render engine, so as little as possible photoshop work should be done.
Around this level of execution image could serve as a tool comunicating with architect while he'd still be in progress of creation of the object(architecture/design). You see bit of environment for scale, but don't put too much attention for distracting details. Changed geometry, re-rendered output could be swapped in ps under all non-destructive adjustment layers so the changes should visible side by side, without spending too much time. While at the same time moving to final presentation You can incrementally tweak image adding more and more details for environment if needed.
This is and will remain as WIP that I'd might take a fresh look after some time, depending on c&c or changed taste. I like the mood and object of interest itself. But now let's try to forget 'bout it.
3.
..got rid of some elements, looking forward to finish texturing, etc.
No big changes ahead, but still few steps away from completing.
2.
thumb of final framing.
still a lot of things to add, elements to blend,
but starting to like where this one is going =)..
1.
Small personal project I'm workin' - light & mood is almost there,
time to play with textures & adding some extra details, etc. =)
Cheers
NVN
its a little screen...but it looks cool ;-)
glimpse
NVN wrote:its a little screen...but it looks cool ;-)
Thanks, NVN ;)
I usually try to keep mine WIPs from other eyes, but..
though of sharing - always nice to get some constructive C&C
I do enjoy lookin' to these work-in-progress threads around too,
as they give a bit more to understand 'bout other's workflows.
cheers
Return to “Works In Progress”
