two sided materials for book page
marcojaco
Hi to everyone, I would like to know how can I place in a page two different texts for back and front page in a 3d book.
(I'm using cinema 4d)
Thank you very much
fluxiw
I have the same problem. Did you able to find how to do it? :roll:
Thanks.
i7 3770K || 2xGTX Titan 3gb || 32gb Ram || Win7x64 || Cinema 4d R15
FooZe
Unfortunately, octane doesn't support double sided materials so you will need to make the page geometrically double sided (some thickness) so each side can have either a different material applied, or the same material with each side having different UV's to suit displaying the correct portion of an image that contains both sides.
Imagemaker
Hi
You can use Mix material for the page plane with the 'Amount' set to Side. Material1 front, Material2 back. (C4D ver 2.25 R3)
adroewer
Does that work for anybody? I did not get any results.
you can use a Mix Texture node in diffuse pin of your material or a Mix Material between two different page materials, with the Polygon Side node in the amount of the Mix Texture or Material node.
Look at this other similar discussion:
viewtopic.php?f=6&t=54391&hilit=money+paper#p276637
