Support for import obj sequence ?
Andygraph3D
Is it possible add this feature in poser plugin ?
just i want import obj sequence from realflow ;-)
The plugin takes it's geometry from the Poser scene - so you would need to get the Realflow geometry into the Poser scene - then animate with the "refresh scene each frame" option ON. But I haven't used Realflow - so I'm not sure how hard it would be to get that geom into Poser.
The other option would be to export the poser scene (without the Realflow geometry) to OCS, then use some LUA code to merge the Poser scene with the Realflow OBJ's in Octane Standalone.
ch0pper
Andy a I'm also interested if you get this to work please let me know
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
Andygraph3D
I'm not python programmer :-(
i believe is need found i way for create a python script for import obj sequence in poser ..
import all frames and animated and show and hide frame by frame ?!
blender to modo
http://www.youtube.com/watch?v=yx0VpjGgAyc
blender to c4d
http://www.vimeo.com/58878160
xxdanbrowne
There's an ugly slow way to do it in the standalone:
Convert the particles to geometry and have realflow export an .obj sequence.
Then load each obj one at a time into the scene and connect it separatately to it's own group and then manually connect each
of the realflow obj groups to the main groups at render time.
It's likely that the connect/disconnect piece could be done in lua script i'm guessing.
Andygraph3D
Its very ugly ;-)
But maybe is the only solution ..
is it possible import the file in octane standalone save the project and import it in poser plugin for animated camera or other props?
Poser is really not setup for this sort of thing - I think you would be better using another 3d app to do this.
spartan00j
Andygraph3D wrote:Is it possible add this feature in poser plugin ?
Yo! I know this is a old topic but I found a solution. I exported a liquid simulation out of Houdini as a Alembic (ABC) format. Import the ABC sequence into octane and use the same method to import VDB but use ABC file instead.
https://vimeo.com/211622194
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Very nice!
spartan00j
face_off wrote:Very nice!
Thank paul!
I've been experimenting with the proxy feature a lot.
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
