Cuda Compute 6
This could be a game changer if its implemented in octane I recon
http://www.theregister.co.uk/2013/11/16 ... ory_party/
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
I hope you are wrong
High hopes I guess.
This dream is old...
In the 90th, the Matrox Millennium had a 6MB addon module to expand the VRam
face
face
http://vimeo.com/user2509578
Actually, I think witpapier is right.
If you look at nVidia's own example here:
http://devblogs.nvidia.com/parallelfora ... in-cuda-6/
Perhaps someone with a deeper understanding of the process mentioned here can chime in?
Win 7 pro 64 | 3 x Asus GTX Titan | i7 3930 OC 4.2 | 32GB | Octane Cinema4D plugin | R14
CUDA toolkit 6 just seems (it's not released yet) to hide the complexity of shuffling data from and to the GPU. It doesn't magically solve the problem that you have to shuffle data between CPU and GPU. Data is sent/received to/from the GPU via the PCI bus which is orders of magnitudes slower than than the memory transfer directly from VRAM to the GPU.
-> So even it may look like you are using one big memory blob, spanning the host and GPU RAM, you are not and I expect the performance loss to be the same as with previous toolkits. The only difference is, it's easier to program.
Thanks for the insight Abstrax!abstrax wrote:CUDA toolkit 6 just seems (it's not released yet) to hide the complexity of shuffling data from and to the GPU. It doesn't magically solve the problem that you have to shuffle data between CPU and GPU. Data is sent/received to/from the GPU via the PCI bus which is orders of magnitudes slower than than the memory transfer directly from VRAM to the GPU.
Seems that unified memory is not the silver bullet that we were perhaps hoping for.
- maya-heyes
But I think this feature would be very helpful in implementing hybrid (CPU / GPU) CG algorithms .. or algorithms that are difficult to be implemented purely on GPU
