Get information from a mesh node?
Forum for OctaneRender Lua scripting examples, discussion and support.
grimm
Is there a way yet to query a mesh node and get information about it? I'm interested in getting the mesh nodes position and bounding box. I have been able to pull the vertices out of the node and I can calculate the position and bounding box with a function from them. But, is there a better way? Thanks :)
Jason
stratified
Hi jason,
Unfortunately not, for the bounding box you have to go via the raw vertex data. And depending on your scene, you can get the position via placement or scatter nodes.
cheers,
Thomas
grimm
Thanks Thomas,
I will finish up my function to do it then, it's just really slow, depending on the number of vertices in the mesh. :(
Jason
stratified
grimm wrote:Thanks Thomas,
Jason
The main issue that goes for all array attributes is that they are fully copied over the C/lua boundary which is very slow for huge arrays like in the mesh node... . We might try to come up with something smarter in the future, we just don't know what :)
cheers,
Thomas
grimm
Ok, it's much faster than I thought. :D I was printing the values out so I could see if I was getting the right information and that was slowing things down. Onwards! :)
Jason
stratified
grimm wrote:Ok, it's much faster than I thought. :D I was printing the values out so I could see if I was getting the right information and that was slowing things down. Onwards! :)
Jason
Great! Yeah, printing is just slow and if you try to print something like a million lines it will just take forever.
If you have heaps of output to print it's better to run the script from the menu and look at the log output. The log window is much faster because it isn't updated in real time.
cheers,
Thomas
grimm
Thanks Thomas, that's good to know. Here is my function if anyone is interested, any ideas to make it better will be greatly appreciated.
-- calculate the statistics of a mesh and return a table of those values
function getMeshStats(verts)
  local meshStats = {}
  local minX = 0
  local maxX = 0
  local minY = 0
  local maxY = 0
  local minZ = 0
  local maxZ = 0
  local lengthX = 0
  local lengthY = 0
  local lengthZ = 0
  local x, y, z
  -- find the bounding box
  for k,v in pairs(verts) do
    x = v[1]
    if x > maxX then maxX = x end
    if x < minX then minX = x end
    y = v[2]
    if y > maxY then maxY = y end
    if y < minY then minY = y end
    z = v[3]
    if z > maxZ then maxZ = z end
    if z < minZ then minZ = z end
  end
  meshStats["min_x"] = minX
  meshStats["max_x"] = maxX
  meshStats["min_y"] = minY
  meshStats["max_y"] = maxY
  meshStats["min_z"] = minZ
  meshStats["max_z"] = maxZ
  -- find the mesh's length for each axis
  lengthX = maxX - minX
  lengthY = maxY - minY
  lengthZ = maxZ - minZ
  meshStats["x_len"] = lengthX
  meshStats["y_len"] = lengthY
  meshStats["z_len"] = lengthZ
  -- find the mesh's position
  local posX = lengthX/2.0 + minX
  local posY = lengthY/2.0 + minY
  local posZ = lengthZ/2.0 + minZ
  meshStats["pos_x"] = posX
  meshStats["pos_y"] = posY
  meshStats["pos_z"] = posZ
  return meshStats
end
selectedMesh = octane.project.getSelection()[1]
verts = selectedMesh:getAttribute(octane.A_VERTICES)
meshStats = getMeshStats(verts)
print "X info"
print(meshStats["pos_x"])
print(meshStats["min_x"])
print(meshStats["max_x"])
print "Y info"
print(meshStats["pos_y"])
print(meshStats["min_y"])
print(meshStats["max_y"])
print "Z info"
print(meshStats["pos_z"])
print(meshStats["min_z"])
print(meshStats["max_z"])
If you do run the script, just make sure to select a mesh node first. Otherwise it will not work. :)
Jason
thanks jason, useful to understand the scale and orientation of a mesh ;)
note: the result don't take care of a different scale setting in the preferences of the mesh, and is always displayed in meters.
grimm
Hi bepeg4d,
Yes, in this case I needed the raw numbers, but that doesn't mean you can't add your own scalular to the script. :D
Jason
shouldn't come up without any calculation?
i mean, if the mesh is already scaled, the script should give the current dimensions... at least this is what i was expected :)
Return to “Lua Scripting”
