OctaneRender® for 3ds max® v1.25[Test]
Karba
Changes since 1.22a
  • IES Lights fix.
  • Live DB fix
  • Fixed box mapping in object space.
  • Allow negative values for the object scale.
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013. For 2014 use files from 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.25.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.25.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.25.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.25.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
draftart
You are the star!
Thanks a lot Karba
bicket
Thanks KArba
I'll test it right now.
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
mykola1985
Thanx! GREAT!!!
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
bicket
KArba
Why octane works fine when unit is centimeters and don't work when it's meters.
I mean bump map is broken with projection mapping (in meters) and work fine when unit is centimeter.
PortFolio
Karba
bicket wrote:KArba
What do you mean broken?
Could you post some images?
bicket
Karba wrote:
bicket wrote:KArba
here the basic scene
you can see diffuse works but bump is broken.
test.zip
(16.75 KiB) Downloaded 213 times
PortFolio
Karba
bicket wrote:
Karba wrote:
bicket wrote:KArba
The scale is too big.
We will thing about ability set bump power bigger than 1.
solomon
downloading... will test some scenes
Solomon W. Jagwe
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
nildoe
Can anybody tell me if the procedural textures now get stuck on the mesh when these are deforming or transforming?
this is much needed to avoid having to use resort to maps to save on Video Ram :(
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
Return to “Autodesk 3Ds Max”
