Clear Cache?
gold
I have a show stopping problem of clearing the cache. I change textures in poser, but they don't
update to Octane. { yes I have auto refresh on, even hit it on and off } Even closing poser and reopening the file doesn't seem to fix.
help!
Are you changing the texture map in the Poser material or the plugin?
gold
I'm changing jpg texture maps in poser.
Then I also changed them in the plugin . Plugin didn't seem to recognize the change either.
samhal
gold wrote:I'm changing jpg texture maps in poser.
Maybe I'm misunderstanding. Are you MANUALLY changing all the texture changes in the plugin? If so, a much quicker way is to select the 'reconvert' (right menu option) in the plugin to re-import the changes from poser all at once.
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
gold
Samhal,
You saved the day! Thanks. Yes I was manually doing it - didn't work. But the reimport
file seemed to do the trick! { is that the same as "reconvert" ? Im still on 1.17
thanks
samhal
gold wrote:Samhal,
thanks
:D You're welcome! Yep, it's the same function, just renamed.
See "Material Conversion" at http://render.otoy.com/manuals/Poser/?page_id=61 for more details.
gold
thanks Paul,
I will check it out.
Return to “Poser”
