Just a quick one.. I noticed that changing the smoothing angle for any given surface requires one to reload IPR to see the changes. Is this a bug or a necessary evil. Can be quite time consuming for larger scenes.
Dino.
Smoothing Angle requires reload IPR
Yes, this is known issue. Problem is that smoothed normals are not available in Lightwave until you change the smoothing angle parameter. So after change this parameter, Octane needs to reload the scene again to get the new smoothed normals from the Lightwave scene. Currently I don't know a way to fix it.Reversion1970 wrote:Just a quick one.. I noticed that changing the smoothing angle for any given surface requires one to reload IPR to see the changes. Is this a bug or a necessary evil. Can be quite time consuming for larger scenes.
Dino.
Thanks Juanjo, whilst not a huge issue it would be a significant timesaver in some scenes. My workaround for now is to set smothing values in modeller, leaving less tweaking in layout. Do you see a potential fix in future versions of the plugin/lightwave/sdk?
Dino.
Dino.
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
CG Artist
Melbourne Australia
