inverting faloff node values?
Locked
marchermitte
Hello there!
I'm strugling with this very simple problem, I need to apply the fallof node to an emiter via the textured emision node but I need to invert the value (brighter in the middle, darker outside) but the invert node deosn't do the job, neither the clamp node with max value = 0 and min =100.
Any idea?
Thank you!
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
gordonrobb
Dont you just swap the values in in teh node?
marchermitte
I thought about that, but faloff and incidence are not the same inputs, It wouldn't work (if I understood what you said correctly) . Using the clamp tool and swaping the min and max values doesn't work either.
Marc Hermitte
roeland
Locking this topic, you can continue discussion here.
Roeland
Locked
