Greyscale texture limit
bpzen
Hi all,
I thought i saw a post on this but i cant find it.
I am running into a render with lots of props hitting the limit 87 / 68 :( . Are there recomendations to allow me keeping the props and getting around this error? Thanks for any help.
The other question I have is how I kno who wmany greyscale textures my card can support, I have a GTX 770 with 4 gig ram, I actaully dont think i am running out of the greyscale textures as i dont see any missing textures in teh render.
Is this something liste don teh specs of teh card and I assume I have to adjust the default.py settigns accordingly perhaps?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
See question 19 at http://render.otoy.com/manuals/Poser/?page_id=182.
The simple solution is a a) remove bump maps off distant objects, or replace the bump map with a procedural texture, and b) switch the node type of some of the bump map from FloatImage to Image (so it uses an RGB slot instead of a Greyscale slot). I plan to add a rightclick command to do b) for you for a particular figure/prop in the near future.
FooZe
Hi bpzen,
The texture count limitations are in the first item of the FAQ page here (among other places):
http://render.otoy.com/faqs.php
The 770 will be compute 3.0 or above so you will be looking at:
144 LDR (8 bit) RGBA, 68 LDR (8 bit) greyscale, 10 HDR (16 bit) RGBA and 10 HDR (16 bit) greyscale
Chris.
bpzen
Thank you both !
I will mess with teh bump maps on teh hidden objecs I can get it down to with in teh 68
Is that a limitation of Octane or teh Videio card?
For large scens thats a drag to deal with but mehhh at least there is a work around
FooZe
Mostly hardware, this texture count comes from CUDA and can change depending on the compute capability of the card.
Chris.
MildMustard
What are you current limits on Cuda 7 and 8 on the 9 and 10 series? (Including RGB) I can't find info on this.
There are no limits on the number of texturemaps you can have.
MildMustard
Ah that is great news! Thanks Paul!
Return to “Poser”
