Octane Sketchup Exporter - Full 1022-10
TIG
Here's version 1022-10
Octane_1022-10.zip
(515.75 KiB) Downloaded 368 times
The temp cmd files are now made back in the project-folder on PC following reports of glitches with other 'temp' locations. They are also easier to find as they do not auto-delete until the main Exporter dialog is closed.
Please extract and install the files as explained in the README or Help PDF....
Although if affects PC users only can all of you try it, in case I have broken something on the MAC inadvertently !
Feedback please...
TIG
timbarnes
Thanks, TIG. So far it seems to be working well.
tim
Mac Pro 3,1 / Lion / 14G RAM / ATI HD 2600 / nVidia GTX 470
i5-750 / Windows 7 Pro 64bit / 8G RAM / Quadro FX 580
Revit 2011, SketchUp 8, Rhino
timbarnes
Unfortunately it seems to be unreliable on my machine. The latest behavior is that when I click "Render Frame", it says it's complete, but Octane never opens.
I get the following in the Ruby Console:
Error: #<NameError: undefined local variable or method `f' for #<Octane:0x7050c24>>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2750:in `export_group'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2750:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2722:in `export_obj'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2722:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2700:in `export_start'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2685:in `do_export'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:2633:in `run_exporter'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:1442:in `export'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:1493:in `render'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:352:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:443:in `call'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:443:in `show_modal'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:443:in `dialog'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:409:in `activate'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:3142:in `select_tool'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:3142:in `octane'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Octane/Octane_1022.rb:3154
It seems that the exporter hasn't finished, because the .obj file is shown as being "in use" if I try to look at it.
My model checks out OK with SketchUp, and I get the same problem if I try to just output the .obj file.
I've attached the model for you to try.
tim
TIG
Tim
The error is from a typo by me... 'f' should have been 'ci' - or vice versa...
Strangely it doesn't throw an error for me - it within alot of nested tests that I mustn't have triggered - so I suspect it's a combination of factors that you have managed to get it to run and then fail...
I will make the fix and issue an updated version asap...
TIG
Return to “SketchUp”
