import setting for skin
Moderator: BK
alaman64
Just wondering if there is an easier way to do this.
When i apply a new texture to Genesis 2, i then go to octane materials and select genesis and change all materials to glossy in one shot. Easy only takes a couple of clicks. Unfortunately the default setting roughness is way to low and the skin looks like it's wrapped in plastic. I then have to select all the individual skin components that were converted to glossy and change the roughness for each one to .2
This gives me a very good skin setting.
I was wondering if there is an easier way to do this, instead of clicking on each skin setting. Is their a parameter file i can change that has the default value for roughness? Or is there some other way, I don't know of?
Nick
Asus Z97-A / usb 3.1 - Windows 10 - 980 ti - Titan Black - Titan Z - Daz Studio
t_3
unfortunately no, not yet; amongst all the new features currently in the works is a multi-edit mode for the mat tab - means select any number of materials and edit similar parameters at once. templating is another one that should notably speed up the workflow...
Return to “DAZ Studio”
