OctaneRender® for Maya® 1.20.2 - 1.6 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2012, 2013, 2013.5 / 32-bit & 64-bit and 2014 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 359€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Added "Reshapable proxy" type to shapes. Now the "Movable proxies" animation mode can be tuned to be even faster: if you don't change the shape from frame to frame (only its transforms) - the mesh will not be recompiled every frame if it has "Movable proxy" type. It will only be recompiled in every frame if it has "Reshapable proxy" type. So, if you have some not changable mesh shape which just scales-rotates-transforms in animation - set it as "Movable proxy". If this mesh changes its shape from frame to frame - set it as "Reshapable proxy".
  • Instancer now works in "Movable proxies" animation mode too (its shapes should be of type "Movable proxy" or "Reshapable proxy" in this case).
  • Some speed optimizations...;)
  • Minor bug fixes...
DOWNLOAD
OctaneRender for Maya 1.20.2 - 1.6 (76.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
solomon
Awesome!!
Solomon W. Jagwe
http://www.sowl.com | http://www.galiwango.com | http://www.nkozaandnankya.com
solomon
Octane Light node is not emitting light at all, it's still broken in this build as well.
Solomon W. Jagwe
Yes, it will be fixed in next version soon.
Next version HERE.;)
solomon
JimStar wrote:Next version HERE.;)
let me give it a try. Thanks
Solomon W. Jagwe
Return to “Autodesk Maya”
