OctaneRender® for 3ds max® v1.22[Test]
Karba
Changes since 1.17
This build can be unstable. Don't use it for major projects.
  • Image Texture Transforms (scale, rotation, translation).
  • Image Texture border modes (Wrap, Mirror, Black, White, Clamp)
  • Internal mapping (Planar, Box, Cylindrical, Spherical, Perspective)
  • Object Properties (general visibility, camera visibility, shadows casting)
  • Optimization of BRDF models
  • New Node System (affects performance and stability only, no visible changes)
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013. For 2014 use files from 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _v1.22.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _v1.22.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _v1.22.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _v1.22.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
tonycho
Great more flexibility
Thanks Karba :D
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
bicket
Thanks Karba
I give a try now!
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
bicket
Karba,
Bug : info channel is broken => Max crash :(
Where is the rotation of texture environment ? Do I have to translate the 2D map in order to see the environment rotation ?
PortFolio
mbetke
What means "Optimization of BRDF models"?
Do I need to adjust materials new?
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
bicket
Changes Noticed :
- FilmWidth and FilmIndex doesn't work the same way as 1.20.
first Bugs :
- changing kernel engine make 3dsmax crashs
- first octane render viewport ok, when i launch it again in the same scene, no more textures
PortFolio
mikinik
I too have crashe when reopen octanerender viewport and there are other unpredictable crashes. (
error in the 3ds max dump file such - "(1630.4c60): Access violation - code c0000005 ntdll!NtGetContextThread+0xa: 00000000`77971f8a c3 ret"
film index doesn't work in specular material
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
marcio_max
• Crash when reopen Octane Viewport.
• Info Channel not work.
• Changing kernel engine with open Octane viewport it's fine.
I'm using 3ds Max 2014 x64.
Thanx! :D
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
kevinshane
Thanks for sharing~ Mr.Karba! Also I found a bug , when I select the emitter objects and then turn off the "Visible to Camera", it shows totally a black plane(which means still visible in viewport,both black and lights)~ could u please fix that?
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
mykola1985
WOW, seems faster... :o lots of instability and crashes with kernel changes.
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
Return to “Autodesk 3Ds Max”
