Problem with daylight Tag
- cglittenberg
- Contact:
I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
Dr. Carl Glittenberg
Glittenberg Medical Visualizations
Intel(R) Core(TM)i7 CPU 860 @ 2.80Ghz 2.80Ghz 6,00 GB RAM Windows 7 Home Premium Nvidia GeForce GTX 480
be sure it's enabledcglittenberg wrote:I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
- cglittenberg
- Contact:
What do you mean? Where?aoktar wrote:be sure it's enabledcglittenberg wrote:I have a problem with the daylight tag. Changing the time or date does not have an effect. It will just stay with the lighting that was when you created the tag. Is there a work around?
I just created a sunlight tag in the Octane dialog. The sky was created just fine. The sun renders correctly. I just cant change the time. Where do I enable?
it has suntag and default is disabled. You must activate
please check last image in page:
http://render.otoy.com/manuals/Cinema4D/?page_id=104
- cglittenberg
- Contact:
Thanks...you are the quickest problem solver ever!aoktar wrote:it has suntag and default is disabled. You must activate
