Turntable animations in Lua (part 1)
Forum for OctaneRender Lua scripting examples, discussion and support.
stratified
hi all,
Some of you already noticed that the turntable and daylight animations disappeared. Let's fix that by rebuilding them in Lua. In this first tutorial we'll show how to build the user interface for the turntable animation. In the next tutorial we'll show how to do the actual rendering of these animations.
Gui components in the Lua API are managed via properties, just a fancy name for a table of key-value pairs. In the API browser you can find what properties look like. All properties in the API have the PROP_ prefix. When creating a gui component we just create properties and pass them into the octane.gui.create function. When creating a component, all properties are optional except for the type property. Octane needs to now what kind of component to create. When certain properties are omitted, Octane will choose some sane defaults.
The things we like to control in a turntable animation are:
  • The rotation angle, the number of degrees we turn around the target position on a circle arc.
  • The start angle, we might want to start somewhere halfway the circle.
  • The target offset, the distance from the camera position to the target position.
  • The duration in seconds of our animation.
  • The framerate for our animation
  • The number of frames we'd like to render, this is coupled to the duration and the frame rate.
  • The quality, how many samples/px we like per frame of our animation.
  • It's always handy to specify where the rendered frames are saved.
  • A render button to start rendering the animation.
  • A cancel button for when we change our mind.
  • Just for eye candy let's add a progress bar so we know if we still have time for coffee.
Our component will have heaps of text labels so lets create a utility function to create a text label. All the function does is create a label from the passed in parameters and return it:
-- creates a text label and returns it
local function createLabel(text)
    return octane.gui.create
        type   = octane.gui.componentType.LABEL,    -- type of component
        text   = text,                              -- text that appears on the label
        width  = 100,                               -- width of the label in pixels
        height = 24,                                -- height of the label in pixels
end
Numeric values in Octane are usually manipulated with sliders so lets create a function to create a slider:
-- creates a slider and returns it
local function createSlider(value, min, max, step)
        type     = octane.gui.componentType.SLIDER, -- type of the component
        width    = 400,                             -- width of the slider in pixels
        height   = 20,                              -- height of the slider in pixels
        value    = value,                           -- value of the slider
        minValue = min,                             -- minimum value of the slider
        maxValue = max,                             -- maximum value of the slider
        step     = step,                            -- interval between 2 discrete slider values
end
Now let's make sure our functions pay off and create some sliders and labels. Because slider don't have text, we put a text label in front of each slider to tell what the slider does:
-- lets create a bunch of labels and sliders
local degLbl       = createLabel("Degrees")
local offsetLbl    = createLabel("Start Angle")
local targetLbl    = createLabel("Target Offset")
local durationLbl  = createLabel("Duration")
local frameRateLbl = createLabel("Framerate")
local frameLbl     = createLabel("Frames")
local samplesLbl = createLabel("Samples/px")
local degSlider       = createSlider(360, -360 , 360, 1)
local offsetSlider    = createSlider(0  , -180 , 180, 1)
local targetSlider    = createSlider(10 , 0.001, 100, 0.001)
local durationSlider  = createSlider(10 , 1 , 3600  , 1)
local frameRateSlider = createSlider(25 , 10, 120   , 1)
local frameSlider     = createSlider(250, 10, 432000, 1)
local samplesSlider   = createSlider(400, 1 , 16000, 1)
With Octane you can choose to manually layout all the components by specifying the x and y offsets of the components. This will get you pixel perfect interfaces but it's tedious. We prefer to use the group component. A group component is a grid of rows and columns. Each cell of the grid takes exactly one component. The group component will make sure that the components are nicely aligned. Optionally the group component can have a border around it with a title. So let's create a group component to layout our labels and sliders:
-- manual layouting is tedious so let's add all our stuff in a group.
local settingsGrp = octane.gui.create
    type     = octane.gui.componentType.GROUP,  -- type of component
    text     = "Settings",                      -- title for the group
    rows     = 7,                               -- number of rows in the grid
    cols     = 2,                               -- number of colums in the grid
    -- the children is a list of child component that go in each cell. The cells
    -- are filled left to right, top to bottom. I just formatted the list to show
    -- where each component goes in the grid.
    children =
        degLbl           , degSlider       ,
        offsetLbl        , offsetSlider    ,
        targetLbl        , targetSlider    ,
        durationLbl      , durationSlider  ,
        frameRateLbl     , frameRateSlider ,
        frameLbl         , frameSlider     ,
        samplesLbl       , samplesSlider   ,
    padding  = { 2 },   -- internal padding in each cell
    inset    = { 5 },   -- inset of the group component itself
We don't want to manually specify the path to the output file so let's create a button that when clicked shows the user a dialog where he can choose a file. Next to the button we create a text editor that shows the path the user has chosen. We don't enable the text editor to prevent the user
from manually typing in some bogus. We pack these components in a group component:
-- create a button to show a file chooser
local fileChooseButton = octane.gui.create
    type     = octane.gui.componentType.BUTTON,
    text     = "Output...",
    width    = 80,
    height   = 20,
-- create an editor that will show the chosen file path
local fileEditor = octane.gui.create
    type    = octane.gui.componentType.TEXT_EDITOR,
    text    = "",
    x       = 20,
    width   = 400,
    height  = 20,
    enable  = false,
-- for layouting the button and the editor we use a group
local fileGrp = octane.gui.create
    text     = "Output",
    rows     = 1,
    cols     = 2,
    children =
        fileChooseButton, fileEditor,
    padding  = { 2 },
    inset    = { 5 },
For eye candy let's add a progress bar. We'd like to have it 80% the width of the file group above
so we just get the properties of the file group and get the width property and multiply it by 0.8. Afterwards we put the progress bar in a group. We could add the progress bar directly to the window (we create later) but it's easier to layout when it's embedded in a group:
-- eye candy, a progress bar
local progressBar = octane.gui.create
    type   = octane.gui.componentType.PROGRESS_BAR,
    text   = "render progress",
    width  = fileGrp:getProperties().width * 0.8, -- as wide as the group above
    height = 20,
-- for layouting the progress bar
local progressGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 1,
    children = { progressBar },
    padding  = { 10 },
    centre   = true,    -- centre the progress bar in it's cell
    border   = false,
We need 2 buttons to start rendering and to cancel if necessary. The same routine, we create the buttons and add them to a group for convenience. On this group, we don't show the border:
-- render & cancel buttons
local renderButton = octane.gui.create
    text   = "Render",
    width  = 80,
    height = 20,
local cancelButton = octane.gui.create
    text   = "Cancel",
    width  = 80,
    height = 20,
local buttonGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 2,
    children = { renderButton, cancelButton },
    padding  = { 5 },
    border   = false,
To make sure all groups are nicely stacked, we add all the groups in another "layout" group. For this group don't show a border. Quick tip: notice the debug property in the group properties. When this property is set to true it will draw the grid of the group component. This may come in handy when trying to get a layout right.
-- group that layouts the other groups
local layoutGrp = octane.gui.create
    text     = "",
    rows     = 4,
    cols     = 1,
    children =
        settingsGrp,
        fileGrp,
        progressGrp,
        buttonGrp
    centre   = true,
    padding  = { 2 },
    border   = false,
    debug    = false, -- true to show the outlines of the group, handy
Now we have all our components we're ready to create our window. This window has one child, the layout group. We create it with the same size of the layout group to make sure we don't clip our components:
-- window that holds all components
local turntableWindow = octane.gui.create
    type     = octane.gui.componentType.WINDOW,
    text     = "Turntable Animation",
    children = { layoutGrp },
    width    = layoutGrp:getProperties().width, -- same dimensions as the layout group
    height   = layoutGrp:getProperties().height,
So how do we actually react to a button click, a slider change or ... . This is done by hooking up a callback function in the component's properties. This function is called when the user does something with the component (e.g. clicks a button). Each component can have it's own callback function but here let's just have a single callback function. The callback function takes 2 parameters. The first is the component on which the event happened, the second is the event. For now let's say hello from each component:
-- hookup the callback with all the GUI elements
degSlider:updateProperties        { callback = guiCallback }
offsetSlider:updateProperties     { callback = guiCallback }
targetSlider:updateProperties     { callback = guiCallback }
durationSlider:updateProperties   { callback = guiCallback }
frameRateSlider:updateProperties  { callback = guiCallback }
frameSlider:updateProperties      { callback = guiCallback }
samplesSlider:updateProperties    { callback = guiCallback }
fileChooseButton:updateProperties { callback = guiCallback }
renderButton:updateProperties     { callback = guiCallback }
cancelButton:updateProperties     { callback = guiCallback }
turntableWindow:updateProperties  { callback = guiCallback }
Phew, all we have to do now is show the window by calling octane.gui.showWindow. The script will block on this function. All the logic must be done via the callback functions from now on:
-- the script will block here until the window closes
turntableWindow:showWindow()
If all went fine you should have something like this:
-- Turntable animation script
end
end
    children =
-- file output
    text     = "Output...",
    width    = 80,
    height   = 20,
    text    = "",
    x       = 20,
    width   = 400,
    height  = 20,
    enable  = false,
    text     = "Output",
    rows     = 1,
    cols     = 2,
    children =
    padding  = { 2 },
    inset    = { 5 },
-- progress bar
    height = 20,
    text     = "",
    rows     = 1,
    cols     = 1,
    padding  = { 10 },
    border   = false,
    text   = "Render",
    width  = 80,
    height = 20,
    text   = "Cancel",
    width  = 80,
    height = 20,
    text     = "",
    rows     = 1,
    cols     = 2,
    padding  = { 5 },
    border   = false,
    text     = "",
    rows     = 4,
    cols     = 1,
    children =
        settingsGrp,
        fileGrp,
        progressGrp,
        buttonGrp
    centre   = true,
    padding  = { 2 },
    border   = false,
-- callback handling the GUI elements
local function guiCallback(component, event)
    if component == degSlider        then print("hello from degSlider")        end
    if component == offsetSlider     then print("hello from offsetSlider")     end
    if component == targetSlider     then print("hello from targetSlider")     end
    if component == durationSlider   then print("hello from durationSlider")   end
    if component == frameRateSlider  then print("hello from frameRateSlider")  end
    if component == frameSlider      then print("hello from frameSlider")      end
    if component == samplesSlider    then print("hello from samplesSlider")    end
    if component == fileChooseButton then print("hello from fileChooseButton") end
    if component == renderButton     then print("hello from renderButton")     end
    if component == cancelButton     then print("hello from cancelButton")     end
    if component == turntableWindow  then print("hello from turntableWindow")  end
end
And when you run it, it should look like this:
turntable animation component
debugging enabled on the settings group
Next time we'll show you how to do the actual turntable animation rendering. We'll use this script when it's done in the standalone edition. So if somebody comes up with a nicer component, we'll include his instead. This is your chance for eternal glory ;)
cheers,
Thomas
pixelrush
Very good, following along...
What about clockwise/anti clockwise option? Spiral in/out? :o :P
Octane v1.55
abstrax
pixelrush wrote:Very good, following along...
That will be your homework ;)
pixelrush
Come on guys! Where's your Xmas spirit? Take pity on an old man in the festive season. Gasp, cough...bloody wooden leg... :x
Octane v1.55
glimpse
wow! thanks =)
Small question =) I assume it could be possible, but just for clarification.
Could we render turntable with animated piece of geometry?
or is it better to make cam animation for this? =)
amazing upgrade so far & thanks for tutorials!
cheers
stratified
sure, we could modify them later to scrub through animated geometry. First I'll explain how to animate the camera.
We just have to get those damn turntable and daylight animation working again in the standalone ;)
cheers,
Thomas
pixelrush
how do I show line numbers in the editor?
is there undo available? I see ctrl C/V works...
Octane v1.55
stratified
clockwise/anti clockwise will be possible by setting a positive/negative angle.
Spiraling is not that hard, I'll show you after you've done your homework ;)
cheers,
Thomas
pixelrush
OK so I cant find how to show line numbers in the editor. Need this please particularly where you get an error referencing a line no..
Second, looking up the API although the keywords are larger type, it would help if they were a distinct colour as well like red or gold
:arrow: Attachment to forum LUA not allowed
So here is some messing around with UI elements to pass as homework 8-)
Questions for boss coders -
-can you nest a group? possibly not...
-will we be able to run favourite scripts in the Octane UI from either from a pull down list or via an icon?
-- Homework - Turntable animation script with direction and spiral do-dads
end
end
local targetIniLbl = createLabel("Initial")
local targetMidLbl = createLabel("Midpoint")
local targetFinLbl = createLabel("Finish")
local targetIniSlider = createSlider(10 , 0.001, 100, 0.001)
local targetMidSlider = createSlider(10 , 0.001, 100, 0.001)
local targetFinSlider = createSlider(10 , 0.001, 100, 0.001)
local settingsGrp1 = octane.gui.create
rows = 6, -- number of rows in the grid
children =
local settingsGrp2 = octane.gui.create
text = "Target Offset", -- title for the group
rows = 3, -- number of rows in the grid
children =
targetIniLbl , targetIniSlider ,
targetMidLbl , targetMidSlider ,
targetFinLbl , targetFinSlider ,
inset = { 10 }, -- inset of the group component itself
-- file output
text = "Output...",
width = 80,
height = 20,
text = "",
x = 20,
width = 400,
height = 20,
enable = false,
text = "Output",
rows = 1,
cols = 2,
children =
padding = { 2 },
inset = { 5 },
-- progress bar
height = 20,
text = "",
rows = 1,
cols = 1,
padding = { 10 },
border = false,
-- direction, render & cancel buttons
local reverseButton = octane.gui.create
type = octane.gui.componentType.CHECK_BOX,
checked = false,
text = "Reverse",
width = 80,
height = 20,
text = "Render",
width = 80,
height = 20,
text = "Cancel",
width = 80,
height = 20,
text = "",
rows = 1,
cols = 3,
children = { reverseButton, renderButton, cancelButton },
padding = { 5 },
border = false,
text = "",
rows = 5,
cols = 1,
children =
settingsGrp1,
settingsGrp2,
fileGrp,
progressGrp,
buttonGrp
centre = true,
padding = { 2 },
border = false,
if component == targetIniSlider then print("hello from targetIniSlider") end
if component == targetMidSlider then print("hello from targetMidSlider") end
if component == targetFinSlider then print("hello from targetEndSlider") end
if component == reverseButton then print("hello from reverseButton") end
end
targetIniSlider:updateProperties { callback = guiCallback }
targetMidSlider:updateProperties { callback = guiCallback }
targetFinSlider:updateProperties { callback = guiCallback }
reverseButton:updateProperties { callback = guiCallback }
turntableWindow:showWindow()--
Octane v1.55
stratified
pixelrush wrote:how do I show line numbers in the editor?
Unfortunately we don't have line numbers, I know it would be very handy but our UI toolkit doesn't support it so this is something for the future.
Undo should work.
cheers,
Thomas
Return to “Lua Scripting”
