Tackball error after compressing textures
morphious2013
Since Octane won't recognize all 4gb of my card, I tried the python script to compress textures and got this error.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 360, in <module>
w = CompressTexturemaps()
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 57, in __init__
self.EventPropChange(None)
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 142, in EventPropChange
self.fillMaterialsList(f)
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 87, in fillMaterialsList
self.findAllImageFiles(propFigure)
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 114, in findAllImageFiles
self.scanForTexture(node, "diffuse")
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py", line 264, in scanForTexture
scanForTexture(inputs.InNode(), type)
NameError: global name 'scanForTexture' is not defined
Any ideas?
I will fix this in the next 24hrs.
I am in the middle of of major modifications to the Poser plugin, so will not be able to release a fix for this as an entire update to the plugin until Monday. However you can fix it yourself very easily. Edit C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\poserScripts\ScriptsMenu\OctaneRender for Poser\Compress Texture Maps.py.
Change the line 265 from:
to
                    self.scanForTexture(inputs.InNode(), type)
(ie. add a "self." to the start of the line).
Make a backup of the old file first. Give yourself write-access to that file first, otherwise Windows will not allow you to edit it.
The above fix will be in the next version of the plugin.
morphious2013
Thanks Paul. I'll give it a shot.
Return to “Poser”
