How do I simulate a cloth material with backlight shadows?
Moderator: BK
linvanchene
edited and removed by user
UruMike
I would say that depends on what you want to achieve.
The example with the curtains:
Try to think in real world ways. What is a curtain? A weave, a mesh.
So you probably need a transparency map reflecting the mesh. Or perhaps not, depending on how accurate you want it to be.
Plus the thread it is made of would be semi- transparent too maybe, so set the whole material to maybe 80%
I have a free 3d curtain somewhere and used it that way.
Have renders going right now so can't test.
As for the spec mat, I indeed think they need a volume, so your idea with the deformed cube seems reasonable.
Intel i7 | 32gb | Win7pro-64
2 x Geforce GTX 660 ti/2gb +GTX 650 for display| Driver 310.90
DAZ Studio 4.5 Hexagon 2.5 Octane v1.11
roeland
The simplest setup achieving this effect is using a diffuse material with transmission enabled. Remember to make the reflection color ('diffuse' input) darker, because only the part of the light which is not reflected can go through the material.
Roeland
Return to “DAZ Studio”
