Achieving realistic skin
- MaTtY631990
Because there's no SSS, I thought to test a scene to see if you can achieve realistic skin. Any comments on what is lacking or what I can do to get better result.
- MaTtY631990
As well, I was wondering if you could tell me if it will be possible to use a glossy material on top of the skin material to create the sheen on the skin by tweaking an opacity slider in pre 2.3 v5.radiance wrote:very good but it looks too transparent.
maybe add a layer 0.5 CM under her skin with less transmission?
Radiance
intresting
- Kevin Sanderson
LuxRender devs are working on a velvet like skin. Is that possible in Octane?
Did you use a texture on this material ? It looks too smooth IMHO.
Beside that, smoking is bad for skin !
- MaTtY631990
It's just a simple coloured diffuse material with translucency applied.
How did you apply translucency, because I have not found simple way of doing this.MaTtY631990 wrote:It's just a simple coloured diffuse material with translucency applied.
Or could someone do a short video tutorial on this.
Vista 64| 660 GTX | 6600 Quad | 8GB DD2|Maya 2011
create a diffuse material node, see that there are several triangles, each for a different parameter, and a circle which actually is the translucency value, create an RGB node, attach it to the "circle", now you have a diffuse material with translucency controled by RGB, play with it.
