at the beach
MyRho
...it's a mix of a W.I.P. and final ;-)
I've been fiddling around with tonysculptor's SSS-shaders, added this, deleted that, changed this and tweaked that... :|
I still couldn't figure out which texture (map, bump, specular) I should add to which node... but this is the result so far.
Maybe someone can explane how to use the shader correctly in the forums?
M.
MSI MPG Infinite X2 MSI GeForce RTX 4090 24 GB VENTUS Intel i9 14900KF
Nihil sum sine sole.
