System
Dell T7600 (Dual E5-2630, 32Gb memoey)
Nvidia GTX 780 Ti (I use Dual Monitor 1.1920-1200 2.1280-1024)
Windows7 Ultimate Sp1 (64bit)
Some Optimize
Nvidia Force-Enable-Gen3 Applied (PCIe 3.0 Enable)
CPU TURBO Enable
CPU Parking Disable
Scene
Load Sample Scene (Quadripod robot.c4d from libary)
Not Adjust..Render in PictureViewer (Original Scene Size = 1280 x 720)
RenderTime : 52Sec
Some Additional Test (Cinebench R15)
Cinebench R15 OpenGL Mark : 85.26fps
Cinebench R15 CPU Mark : 1313cb
Note :(TurbulenceFD + c4dOctane)
Remove TurbulenceFD Plugin....Just OctaneRender Load
Or
TurbulenceFD + OctaneRender Load.
Copy c4doctane/Lib64(octane.dat, octane.dll,vcomp100.dll) to C4D Root Dir
Do not copy nvapi.dll
My Nvidia GTX 780 Ti.....
- eyeonestudio
- Contact:
Hi eyeonestudio,
nice to hear you are fine with your GTX 780 ti!
What mobo is your xeon system on?
I got a evga GTX 780 ti superclocked last week, but it isn`t recognized by my motherboard (P8Z68 deluxe rev. 1.0)... installed a complete new win 7 sp1 ultimate 64bit system and the same last NVIDIA drivers, but it just shows up as standard vga card with yellow triangle mark in the device manager.
I also have a gtx 580 in the first PCIe slot, the doublesized GTX780 ti only fits in the second slot because of some watercooling elements on the board.
My board only has PCIe 2.0, but I think the GTX780 ti should be down compatible and also run on "older" boards.
Where did you enable this "Nvidia Force-Enable-Gen3 Applied" option?
Thanx,
ChrisVis
Thanx,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
- eyeonestudio
- Contact:
I don't use Modo... Sorry that..
780ti run with PCI-e 2.0 x16 base before Nvidia-Force-Gen3
If you want PCI-e 3.0 x16 Mode, download Nvidia Utility (Link below)
And Run With Command window.
That's It...
http://nvidia.custhelp.com/app/answers/ ... EzbE45X2s=
That's It...
Hi eyeonestudio,
thank you for the link above.
I didn`t ask for modo... I just wanted to know, what mobo (=motherboard) you are using for your xeon system.
thanx,
ChrisVis
thanx,
ChrisVis
